Question about Whirlpool Microwave Ovens
Model No: E.C.N MH6150XMT - O Serial No: Manufactured FGM4508040 2002 Front Door Burning from the Inside
Call the manufacture due possible recall on model
Posted on Jul 22, 2008
What are the dimensions of microwave model MH6150xmt? Sorry, don't know make.
The manufacturer is Whirlpool.
Try asking "searspartsdirect" for help with dimensions, if you do not see this on their web-site.
God bless your efforts.
Feb 27, 2018 | Microwave Ovens
GE Spacemaker XL4100 Model # JVM1450WA has stopped heating
If no fan, check the door switches. If it sounds like it is working then the ma
Dec 31, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Do you have a door handle for a ge model #jvm140h001,serial # DD921459S, MANUFACTURED in February ,1990?It works well and I would like to replace the broken handle.
I can't find a parts breakdown for that door anywhere, and I am using extensive resources. All that is shown is the complete door, which is no longer available. If the handle was available, it would be nearer $100.00 than $50.00. So, it's time for you to get creative. Are you a woodworker, can it be glued, spliced, splinted,...
Good luck.
fil
Mar 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have an Emerson microwave model MWG9115SL, that wont turn off unless I unplug it, or open the door. Can anyone tell me what to do?
contact emerson @ 1-800-909-1240 option 3 is microwave. Make sure you have model number and serial number. We are having the arcing problem and burning smell. They will pick up check and replace.
Oct 06, 2010 | Emerson Microwave Ovens
Buttons including light, cook time, etc will work infrequently
Good news, even though the electronic controls (circuit boards) are different, the touch pads for the two units are the same. As far as the nomenclature behind the model numbers/letters, this information is rarely known or needed.
Please take the time to give this solution a fix ya rating.
Below are some applicable links for you for future reference.
clarkco
owners manual/parts list for MH6150XMT
owners manual/parts list for MH6140XK
Feb 09, 2009 | Whirlpool MH7140XF Microwave Oven
MH6150XMT Turntable and Magnetron do not engage
Looking at the schematic from the mini-manual for this model, the problem should be the secondary (top) door interlock switch or its mount.
(Power-wise, the hood / cooling fan is further "upstream" from the turntable and high voltage section).
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and / or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 24, 2008 | Whirlpool MH6150XMS Microwave Oven
Kenmore over the range Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Dec 05, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
83 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
