Question about Symbol Batch Barcode Scanner P360/460 Memory Scanner
XB:KSU_map_isr:ISR has not task
Hello everyone, I have a Symbol Scanner 360 and after put the scanner on the base on the screen apper UNIT CRADLE, but after that on the screen appers the folowing error:
And then the scanner restarts
Thank You
    Genius:
  • 2,785 Answers
Plz try by reinstalling the scanner
Posted on Jul 21, 2008
How to reset my dvr provision isr 16 ch
open it up and see if there iis a little battery if not try a hard reset
Jul 23, 2014 | Sharp 1/3" Sharp Color Cctv Ccd Ir Outdoor...
Dvr provision isr
How to reset dvr provision isr 16 ch
Feb 05, 2014 | Home Security
My ls4278 is not lighting up when on the cradle, will not scan or charge...i have 3 scanners and cradles and somehow all the scanners stopped working completely..all the cradles have the light on but when...
The most unlikely scenario is that all the bases are defective. If you power your PC off every night, you should purchase a power supply so the scanners can continuously charge. Another issue may be that you need new batteries (also unlikely if they stopped working at the same time). Also try swapping scanners and bases (one scanner from one base and place it with another base) make sure you firmly place the bottom of the scanner in the base to verify there is a good connection with the charging pins. We are here to help if you have further questions.
Tech Support Barcoding Technical Support
May 18, 2011 | Symbol LS 4278 Barcode Scanner
My symbol barcode scanner beeps 4 time while I try to scan. The Manual states that the battery is bad. I replaced the battery & it does the same thing.
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Sep 07, 2010 | Symbol LS3578-ER Rugged Barcode Scanner
COM1 port is not released when scanner is used over RDP
If your scanner has a twain driver, you could install drivers on the device and use Elusiva Remote Scanner from www.Elusiva.com/products/RemoteScanner
Mar 12, 2010 | Symbol Batch Barcode Scanner P360/460...
My Symbol scanner sits in a cradle, and the laser goes off and on, rather than remaining on full time. This is a problem, because when I pass a barcode under the unit, I have to wait until it flashes, and...
Yes Symbol LS2208 would be the best... it has an intellistand that enables presentation scanning and easy switching between hands free and hand held models..
Nov 16, 2009 | Symbol LS3478 Barcode Scanner
DS 3478 Will Not Power UP
make sure you have a 3478 cradle. We ran into that. We have 3478's and 3578's. You have to look at the gun and cradle to match up. 3578 replaces the 3478. Bless Symbols heart the two aren't interchangable. Can't tell the difference except on sticker.
Aug 18, 2009 | Zebra DS3478-SF Wireless Handheld Barcode...
Download Project with MCL-Link or MCL-Designer
Hello Jim,
the device has a special mode for downloading the project. You would need to go to the menu on the P360, activate the mode and put it to the cradle.
You can also scan a special barcode Load New MCL-Designer Application to activate the mode, please find it at the page 1-4 at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3769004apdf
Please make sure that your program in the MCL project is not larger then 4K. MCL has a limit of 4K for any program in a project including the main program.
Dec 09, 2008 | Symbol Batch Barcode Scanner P360/460...
MC9060-G stuck in IPL (initial program loader mode.
Windows Active Sync will not recognise a scanner in IPL mode. You need to install the Symbol Device Configuration Package that is applicable to your scanner/cradle. Once installed and configured you can use SDCP to restore the Hex files needed for basic operation. All the files and loader software can be found at http://support.symbol.com/support/product/softwaredownloads.do
Good Luck
Oct 21, 2008 | Symbol MC9060-G
Symbol barcode scanner, handheld, cordless, yellow
error code communication error the scanner is not communicating with the cradle. It is important that the synapse cable is plugged into the cradle before the cradle power suply is pluged into a outlet. also could be the scanner did not pair up with the cradle correctly try rescanning the barcode on the cradle.
May 29, 2007 | Symbol Batch Barcode Scanner P360/460...
Symbol Batch Barcode Scanner P360/460 Memory Scanner Logo
459 people viewed this question
Top Symbol Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Symbol Office Equipment and Supply Expert? Answer questions, earn points and help others
