Computers & Internet Logo
A
Anonymous Posted on Feb 03, 2011
Profile settings loaded incorrectly. A temporary profile has been loaded. Any changes been that are made using this profile will not be saved
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
17
Points
Check your windows via you properly install and configure it or not.then check the bios setup and check the boot devices and then login with windows. now check the contol pannel of it and then proper do settings if you have the problem regarding to the network connection then check ur main server
2answers
Desktop won't load. It goes to the login screen and I type in my password, and it'll say "Welcome" with the spinning circle for a long time, then it'll load me onto a temporary profile. How do I...
go into control panel and create a new user (dont make it the same name as your old profile) then restart the pc and log into that new profile. To retrieve all your settings favourites etc you will need to say what version of windows you are using
HOW DO I SCAN PICTURES TO MY MAC OSX
Load the item to scan You can scan from the scanner glass or from the ADF (Automatic Document Feeder) tray, if your product has one. Make sure that the product is connected to the computer. Turn the product on. Load the picture or document: Scanner glass : Place the item with the print side down on the scanner glass, and then position it according to the engraved guides around the glass (usually on the right-front corner or the left-front corner). Close the scanner lid. ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. CAUTION:Do not load photos in the ADF. Use the scanner glass instead to prevent damage to photos. Use HP Scan to start a scan Use HP Scan to scan items and edit them to adjust resolution or color, crop, remove red eye, etc. To scan a picture or document, follow these steps: Open the HP Scan program in the Hewlett-Packard folder. From the Scan Profiles screen, click either Pictures ( ) or Documents ( ) . Click Profile Settings , and then adjust any settings in the Capture , Adjust , and Page Options (for documents) or Enhance (for pictures) tabs as appropriate. If you want to save these settings as a custom scan profile to use in the future, follow these steps: Click the drop-down list to the left of Profile Settings , and then click Duplicate Selected Profile . Type a name for the profile in the text box under the profile icon. The new profile saves under Custom Profiles. Click Scan . Make any desired changes to the scan preview by using the icons available in the toolbar and the Adjust window. NOTE: You can use + and ? buttons in the Bottom bar to add or delete pages in the OUTPUT list. You can reorder pages by dragging them to new positions in the Sidebar. Select a destination from the Toolbar: If you opened HP Scan from other software, and want to send the scan to that software, click Return . If you are ready to save, print, or send the scan to a specific destination, click Save , Print , or Send . NOTE: If you are saving the file, make sure to select the file format that you want.
How to activate my mms? globe prepaid
  • For a complete listing of compatible MMS & GPRS phone handsets — send Nokia, Ericsson or Samsung (your handset model) to 2365.
  • To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1) Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
  • Enter 1234 when asked for PIN to save settings.
  • Send an MMS message for only Php 5.00 to activate the service.
or
This tutorial will help you setup your mobile phone and activate/configure GPRS, 3G and MMS features for Globe Telecoms.
GPRS SETTINGS
1. Go to Menu > Choose Settings > Connectivity
2. Go to Data Accounts
3. Create New Account. GPRS/ PS Data
Account Name: MyGlobe GPRS
APN: www.globe.com.ph
4. Save Account
5. Go to Internet Settings
6. Create New Profile
Connect Using: MyGlobe GPRS
7. Save Profile
8. Select the profile MyGlobe WAP in Internet Profile
9. Click Right Soft Key to Choose More and Select Settings
Internet Mode: HTTP
Use Proxy: Yes
Proxy Address: 203.177.042.214
Port Number: 8080
10. Save Settings and repeat Step 9 but this time choose Advance Settings
11. Change Homepage
Title: MyGlobe
Address: http://www.globe.com.ph/globe.asp
12. Save Changes
MyGlobe Internet Settings
3. Create New Account. GPRS / PS Data
Account Name: MyGlobe INTERNET
APN: internet.globe.com.ph
4. Save Account
MyGlobe MMS Settings
1. Go to Menu>Choose Settings>Connectivity
Account Name: MyGlobe MMS
APN: mms.globe.com.ph
4. Save Account
Connect Using: MyGlobe MMS
7. Save Profile
8. Select the profile MyGlobe MMS in Internet Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
11. Click Right Soft Key to Choose More and Select Advance Settings
12. Change Homepage. Enter the following parameters and save the settings
Address: http://192.40.100.22:10021/mmsc
13. Go to Messaging>Settings> Picture Message
14. Edit Message Server : http://192.40.100.22:100.21/mmsc
15. From Message Settings, make your Internet Profile: MyGlobe MMS
MyGlobe Stream Settings
3. Create New Account. GPRS/PS Data
Account Name: MyGlobe Stream
APN: real.globe.com.ph
4. Save Account
5. Go to Streaming Settings
6. Make MyGlobe Stream your default APN.
2helpful
How to open Globe gprs to Nokia 6303
GPRS SETTINGS
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
11. Change Homepage
Title: MyGlobe
12. Save Changes
4. Save Account
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
4. Save Account
Connect Using: MyGlobe Stream
Incorrect info on your site ( FixYa). My home address is listed as my place of business. NEED IT REMOVED! PO BOX ONLY!
GOTO:
http://www.fixya.com/Registration/editprofile.aspx
OR:
How do I update my profile?
  1. Sign in to your FixYa account.
  2. Click on the "My Profile" link at the top of the page.
  3. From your My Profile page, click on the "Edit Profile" link under the Useful Links section in the right column.
  4. When you have made your desired edits, scroll to the bottom of the page and click "Submit" to save your changes.
User profile cannot be loaded .. you have been loaded with a temporary profile
your profile is corrupt. You will need to create a new profile and transfer all your data.
5helpful
2answers
Crackdown freezes as it says loading profile.
You may very well have a bug in one of your saved files/downloads.
To fix this issue, what you will need to do, is delete your gamertag, basically to refresh your xbox HDD, then go to xbox live and go to RECOVER GAAMERTAG,place the email address you used to originally set it up, and recover it. this HAS happened to me once before, and this has a 99.99% of working, now before you start worring, you will not lose your gamertag altogether,....unless you forgot your email address. Let me know how this goes,
thannks
justin
Please rate me
Laptop doesn't normally start
This sounds like an operating system glitch. Enter safe mode at start up by pressing F8. Once in safe mode, log on as administrator and do a system restore to a point that you recall it allowing you to log onto your profile. This should cure it, if not, let me know and we'll try something else.
1helpful
Windows can?t load locally stored profile,
Go into safe mode at start up, log in as administrator, and do a system restore. Pressing F8 at start up will take you to safe mode.
Grand Canyon Tech
Grand Canyon Tech
