Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
Display won't turn back on
Hi, Re: G4 Powerbook 15"  I dropped the laptop and lost my wireless internet connection -  airport was not longer found.  I opened up the battery compartment to reseat the airport card and now that I've closed it back up and restarted, it sounds like it's started, but I get no display - it's completely black.
any ideas?
thanks
  • fezwench Jul 21, 2008
    thanks - that worked as far as the display turning back on. Now I'm just wondering what to do about the wireless connection - do you suggest purchasing a new airport card?
    thanks a lot
  • Apple Master
  • 6,487 Answers
You may need to open it up again and remove first the airport card and turn it back on and if that boot your computer there's a possibility that your airport is causing the problem and the airport may be loose and touching some other parts on it.
Hope that helps...........
Posted on Jul 21, 2008
I have an old PowerBook g4 in my kitchen for listening to pandora and looking up recipes. All of a sudden, the wifi stopped working. It has dropped out a few times before, but I have always been able to...
Cut the airport off and back on again. After that, delete any wifi profiles you have, and then re-add them. This will clear any corrupt profiles and troubleshoot that. If you can't connect to anything after that, check that the airport card is connected securely. If, after all that, it still isn't working, and other devices are able to connect to the same network, then your airport card is probably no longer working.
Nov 09, 2012 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
G4 network settings
This is often a problem with Airport cards becoming defective over time. You mention that you have tried with an ethernet connection as well. When trying, make sure you disable your wireless connection.
In addition, make sure that you are not using a static IP address or, if one is required, that you try assigning a different IP outside of your DHCP scope as you can be experiencing IP address conflicts.
Oct 12, 2012 | Apple PowerBook G4 Mac Notebook
My powerbook g4 no longer recognize my builted in airport, have no airport now. The only way to make my g4 work in hook an either net cable to my g4 into my router. Makes my laptop very stationary, what...
What I would suggest is reseating the airport card as it may be the card has come loose or the cable is not connected properly. The following support page on the apple website will tell you how to do it.
support.apple.com/kb/HT2617
Failing that you will probably have to buy an new airport card or a wireless usb adaptor. You should be able to pick one up from ebay fairly cheaply.
Hope this helps.
Apr 17, 2011 | Apple PowerBook G4 Mac Notebook
My apple powerbook display is just showing blank. I had turned the powerbook G4 and when I went to restart it the display would not show anything. I can hear the startup sound but nothing on the screen....
Just remove ur CMOS battery and harddisk connection from motherboard. And then try to restart it will give u a msg no boot device or OS found.. Now reboot and add the CMOS battery and harddisk on motherboard...
Apr 24, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Display has light, no picture
It may be any one of them, Best bet is if you are on apple protection plan or any other insurance they will fix it for you for free.
Regards
Jul 21, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Restore CD
You don't need a "restore" cd.
You can just use any copy of Tiger.
Borrow one!
Jun 15, 2009 | Apple PowerBook G4 Mac Notebook
I just bought a used powerbook g4 laptop. It worked great and I used it at work to connect wirelessly to the internet. I brought it home and cannot get it to connect to my wireless network. I have a belkin...
You could try changing the security. Some of the older laptops have trouble with the new WPA2 security. Use WEP and you should be OK if this is the problem. Good luck TT
Dec 13, 2008 | Apple PowerBook G4 Mac Notebook
Airport connection - G5 Powerbook
Yes better get a new wireless card if there's a airport that can be connected via USB that will be better..
Good luck....
Jul 21, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
PowerBook g4 15" Screen Won't Display Anything!
your lcd probably just went out or the connecting cable just came loose(its in behind the lcd under the apple logo that lights up when you turn it on) if you open and close it frequently it will cause this
May 26, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple Powerbook G4 17in 1.33Ghz. Tiger OS. Airport problem.
I had a similar problem with my 15" 1.33GHz powerbook G4.
My problem was I couldn't connect to a network right away or at all, or wouldn't properly reconize the card (didn't drop it).
I solved it by removing the airport card from my PowerBook and putting it back into my G4. it should be in the same location.
it's underneath the battery pack.
1. power off your G4
2. remove battery pack
3. there is a latch on the right side (if the charger port is facing down), open it
4. pull back plastic cover tab and gently remove the antenna plug from the airport.
5. pull the plastic tab, until the airport card is removed, keep out for 30+ seconds to ensure it erases any corrupt log file on card it's self.
6 place airport card into the slot again, fully inserting it, it should go 1/8" - 1/4" into your powerbook
7. plug in the antenna plug back into your G4's airport(it should click 2x(very lightly)), flip plastic tab back over top the antenna cord, close you latch.
8. place battery back into your G4
9. plug computer in, turn on and it should work
if not then there is something wrong with the airport card reader, which i don't think it's the case here..
Jan 12, 2008 | Computers & Internet
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
70 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
