Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubichi Hi, read your problem about the concave and when you hit the side it fixes it for a while...how did you fix it? I'm out of work thus no $$ for a service call. Can you help? Thanks..Hendrika
  • 927 Answers
Good Day, out of work;
You have poor connection on the convergence output IC's. It is not a easy chore to do, unless one is experienced solder. Call an authorized factory service center. The cost should not cost over $350.00 ( depends on area).
If you do not repair now, you will experience further problems and then the repairs will be more costly. DO NOW or PAY later.
Good Luck, big IRISH.
Posted on Aug 07, 2008
I was given a P52960 ,2002 rca 52 projection tv and the sides of the piture are concaved in.Can this be fixed easy enough,i am good with electronics/wireing..iI was told by the old owner that the solu
concave or bloated pictures on crt projection tv's are corrected with what's called a 'pincushion' adjustment. Look for it in the menu under video controls.
Dec 22, 2012 | RCA P52960 52" Rear Projection Television
Picture is off the top of the screen everytime it is turned on. If you turn it on and off several times(3-13) it will become watchable. Sometimes it is off the bottom, or both sides are concave. Or it will...
Its a rather old set to be fixing, if off at top or bottom=vertical deflection problem, if sides are concave pin amp circuit---the fact you can turn it on/off several times etc suggests to me maybe bad solder connections somewhere in those circuits.
AS old as this set is keep in mind a lot of the parts for it are no longer available so be careful about spending a ton of money to fix it.
Dec 14, 2012 | Sony KP-61V35 61 in. Rear Projection...
What makes a rip cut on the table saw to end up concave instead of perfectly straight? Does that mean the rip fence is concave from end to end too?
It is doubtful that the fence is concave but this can be checked with a straight-edge. More likely this is caused by the blade having hit a nail on one side and the teeth on that side of the blade are damaged. Hope this helps you.
Oct 18, 2009 | Saws
Concaved screen image, no response on vertical blue converge
I've read some similar problems that tend to indicate that it is a convergence chip problem, so i ordered a convergence kit. I will update you as soon as I get it fixed. Thanks
Mar 22, 2009 | Philips Televison & Video
Right and left side of TV concaved
CALL THE REPAIR PERSON THE ISSUE IS INTERNAL RELATED
Aug 11, 2008 | Akai PT5492S 54" Rear Projection...
Mitsubishi HDTV concave
maybe your problem is easy my friend,focus on the horizontal circuit and try to resolder it.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi tv model WS-55809
that happened to me and i just gently hit it on the top and it fixed itself
Jun 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubichi CS-40FX1
The problem is in a circuit called "pincushion" Most likely you have capacitors failing in that circuitry.
Mar 08, 2008 | Televison & Video
Mitsubishi VS 45501A Projection TV
Model VS-45501A  probably not worth fixing at around 400.00
for a convergence circuit overhaul......T.
Oct 20, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
