Question about Dell Dimension 4600 PC Desktop
NETWORK ADAPTER I REFORMAT MY COMPUTER,BUT THE INTERNET CONNECTION DOESNT WORK.IM USING A BROADBAND CONNECTION.CAN YOU HELP ME TO SOLVE THIS PROBLEM.
    Genius:
  • 1,847 Answers
Reinstall the network adapter from the dell driver cd and reboot the system with the nic pluged in.
Posted on Jul 21, 2008
Can i use connect dongle as wireless adapter
Yes definitely ,I think i need lots more information about router version, IEEE standard.
basically adapter that uses mobile phone networks to provide broadband as a WiFi Dongle while USB WiFi adapter can be used to connect your PC to and existing wirless network provided by a wireless router.
but first you should find out what kind of Internet router you are using and always purchase a Wi-Fi adapter that is compatible with the Wi-Fi standard of your wireless router.
read more information
for more http://www.ebay.co.uk/gds/Buying-a-USB-Wi-Fi-Adapter-Dongle-Can-Make-You-More-Mobile-/10000000177329841/g.html
If you still not able to solve follow us Linksys Router Support .
Apr 17, 2014 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
If your connection remains non-functional, run the Windows Network Repair utility on your computer.
If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
My belkin n USB adapter (f5d8053) has been unable to access the wireless internet at my new place, through the mwn-apr150n medialink wireless n broadband router. My other devices connect fine, it's...
Please check the Network Range B/G/N Signal.
This could be the issue if other aplications are able to connect.
Also try to delete Wifi Profiles using the USB and add fresh wifi networks
If not in install & reinstall the the USB Software on ur pc / laptop
Lastly if this doesnt work try to use the USB Adapter on another network / other device and try to connect
If it doesnt then u have a USB Issue
Cheers
Eddie
Jul 02, 2017 | Belkin Computers & Internet
I have a Dell inspiron 537 sesktop pc and the lan adapter is not recognizing the ethernet lan connection. I reinstalled the drivers etc but it still show " not connected ". Is there anyway to...
To connect to the Internet, certain hardware and services are needed, which are listed below. Without any one of these items, connection to the Internet is not possible.
  • Broadband Internet Service (also known as Internet Service Providers or ISP) - Telephone companies (also known as DSL, which uses a telephone line) and cable TV companies usually offer Internet service.
  • Broadband Modem - Normally, a broadband modem can be rented or purchased from the ISP.
  • Computer with a Network Adapter - This is usually a device located inside the computer.
  • Broadband Router - A router is used to connect all of your computers to the network (but is not needed for a single computer). The router also provides a way to connect to the Internet through the Broadband Modem.
Oct 12, 2011 | Dell Inspiron 537 (DDCWQA1_7) PC Desktop
Why do i keep losing my wireless internet connection?
try to have a reformat again or change the settings of your router or try to reinstall the wireless adapter that you have
May 20, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
NETGEAR Wireless G USB Adaptor Problems
I contacted Bigpond after my whole internet collapsed due to my amature abilities in fixing the internet. >_<" yet they fixed my internet connection by disconnecting my current (DLINK DIR-300) router from the network. hmmmm... the technician also confirmed that my current broadband modem (2WIRE 2071-A) isnt capable of supplying a shared connection to more than one computer!! she also directed me towards a modem with an inbuilt wifi router that "supposedly" is the best option right now. (2701HGV-W) I'm a bit shaky and the stupid NETGEAR adaptor problem still exists - im willing to buy the new modem if its guaranteed to abolish this problem and give me a better internet wise outlook - please any suggestions will be appreiciated =)
Apr 23, 2009 | NetGear Wireless-G USB Adapter...
Windows xp wont connect to internet
Please check you LAN settings on your router (DNS) - usually it is 0.0.0.0 (assigned by provider)
Make sure your PC is using DHCP (TCP/IP properties -> Obtain IP Address Automatically & Obtain DNS server address automatically). Try "ipconfig /all" at others computers and compare with your PC (look at gateway & DNS). See if you can ping gateway and then outside address.
p.s. To access your router open Internet Explorer and enter http://192.168.0.1/
If it is not working, check the default gateway address on working computer and use it instead.
Feb 10, 2009 | D-Link AirPlus DI-524 Wireless Router
USB Broadband to wireless router through desktop PC
If I get you right you are useing a 3g Internet connection and have a router wich conets the 2 computers together, the problem is that you can't share the internet connection.
Without any information about the operateing systems I can tell you the idea:
First you need to disable DHCP server on the router and use static IP addresses on both PC, the IP address should be something like
PC1:
IP: 192.168.0.2
Network mask:255.255.255.0
PC2:
IP: 192.168.0.3
Network mask: 255.255.255.0
Default gateway: 192.168.0.2
In this IP configuration above PC1 has the 3g modem connected.
This was the easy part, hard part is to share the internet connection on the network, that's a little different ritual on every operateing system, try to use google to get your specific one.
However there's a much more easier way to solve all your problems if you can't make it work, but it costs money. All you need to buy is a 3G router and that will do the same thing for you what your old router did.
I did a little search for you on Australian Ebay to see what you can get.
But I'm sure you have your own cheapbfavourite source of computer hardware as well.
Hope this will help you sorting out your porblem.
Regards
Imre
Nov 26, 2008 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
Network adapter
if you have a broadband connection you could try using the USB cable that came with the modem to access the internet as Windows will automatically detect the USB device. So you will still have internet connection until you download the drivers for your network adapter then swap the cable to the network cable and then all your drivers should be intact.
Feb 06, 2008 | Dell Dimension 2350 PC Desktop
Help!
go to start>run, then type ipconfig /flushdns and press enter. If no luck then go to control panel>network connections, then click on your network adapter sometimes called local area connection unless it's wireless and right click>properties, click on the tcp/ip line and click properties and check the obtain ip address is ticked and select ok. Try again and if that doesnt work go back to network connections, right click on your network connection and select uninstal, then restart the notebook and it will reinstall itself for you to try again.
Aug 07, 2007 | IBM ThinkPad A20 2628 Notebook
Dell Dimension 4600 PC Desktop Logo
94 people viewed this question
Alun Cox
