Question about Electrical Supplies
Motion sensing After installing my lantern the sensor dosen't pick up when crossing it's path but comes on when coming from opposit corner meaning head on which people comming up to the door wouldn't triger it Thank you in advance chenoyboy@comcast.net Hampton lighting model HB 4190series
Still need help have not seen a solution or am not sure where to find it?
Posted on Jul 22, 2008
Brinks motion activated security light model 7160w. Only stays on for about 15 seconds. Setting is on 10 minutes. Can someone help?
Sounds like the motion sensor is not picking up motion. Or, does it actually sense motion and only stay on for a short time each time? Try moving the setting, if this is the case and see if you see ANY change. If not, then replace the motion sensor.
Oct 24, 2014 | Home Security
Why when washing hands, faucet keeps shutting off.
Motion sensing technology is a great feature but has some limitations. The motion sensing is limited for one main reason if it senses motion to far away from the faucet the faucet would come on when you walk by so the motion sensor is very restrictive in it's distance and angle of sensing. When you first start washing your hands you probably bring them in close to start the faucet but then lower them or bring them further away from the faucet. This in turn takes your movement away from the sensing eye and the sensor stops sensing movement and shuts the faucet off. Try finding out what distances the sensors movement to see where it stops recognizing that there is someone using the faucet. this will give you an idea of where you have to stay when using the faucet to keep it sensing correctly. I know this seems like a loto f work to use something so intelligent but in fact the faucet is very dump and has a limited function pattern.
One thing to also check if the faucet was working fine but then just started to malfunction is that the sensing eye is not dirty, covered in mineral deposits or the lens is not scratch badly. All the above problems can cause the sensor to miss read motion or have trouble sensing motion. Since this is a moen they are usually very good about replacement parts.
Jun 10, 2014 | Moen One Handle High Arc Pulldown Kitchen...
How install a sensing switch WSP-250
This sensor has 2 wires coming from it, a red one and a black one. You must connect the feed (hot) wire from house to black wire and the red goes to the light wire.
Nov 21, 2013 | Cooper Wiring Devices Motion Sensing...
Why does motion sensor not fully illuminate a fluorescent 4' light?
many motion sensor do not work with fluro tubes as stated on the fitting instructions as it has the same affect as you turning the switch on and and on to change from auto to manual operation
the problem comes from the ballast and the starter operation
Jul 04, 2017 | Heath Zenith Occupancy Motion Sensor Wall...
Air conditioning won't blow air
sounds like your feeling air flow from motion your blower dosen't sound like its coming on try when you are sitting still with car running turnibg on the blower if it dosen't come on it could be anything from a bad fuse to a bad blower motor
Jul 07, 2012 | 2003 Buick Rendezvous
I bought two motion sensing diecast lanterns model HB-4190 series, SKU 248-593 and the instructions are hard to understand. To make it easy tell me how to set the device if I want it to come on only if...
Hello Gerald. Each switch has a function. the the test-1-5-10 allows you to set it to test or an on period of 1 or 5 or 10 minutes. The off-3-6-dusk to dawn allows you to turn it off completely, operate from dusk for 3 hours, operate from dusk for 6 hours or operate from dusk to dawn. By operate I mean turn on and then stay on for the number of minutes you set it to with the other switch.
what's nice about the test setting is that with it allows you to check and b sure that the light will come on during daylight by setting the one switch to test and the otner to any setting but off.
If you leave the 2nd switch set to off the first switch will not allow you to test it.
Joe
May 22, 2011 | Garden
I have a Cat Eye Strada cycling computer model CC-RD200 that I have been using for the last couple of months. This model comes with a cadence sensor (as well as a speed sensor) that I cannot get to work. I...
It sounds like you know what's wrong - distance. Take the magnet in your hand and wave it past the cadence sensor to see if THAT works.
As far as why your crankarm and chainstay are too far apart, well, maybe your bottom bracket is too long or something, but it is mostly beyond the scope of anyone who can't see it to judge. Take it to a bike shop and ask them.
Aug 03, 2010 | Cadence Cat Eye Strada Computer
Sixaxis motion control problem
i played that game on my PS3 but i don't think it makes use of the motion feature in the controller. If you want a game that makes complete use of this feature i would recomend the game Lair
Jan 26, 2008 | Sony PlayStation® 3 (60 GB) Console
Electrical Supplies Logo
81 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
