I accidentally pulled out a Verbatim 4 gb stick from my computer, without realizing that it should only be removed in the "safe" mode. Now it won't work. Is it permanently damaged or can it be repaired or reprogrammed? If so, how?
  • 80 Answers
Hi im wesley. please plug the stick in your pc if it shows then simply go to my computer right click on the stick and say format it will then work as only data on the disk has been damaged but if it doesnt show then it is unrepairable you need to buy a new one.
Posted on Jul 21, 2008
I have a SJ25M2 HDD which is not detected by any PC or any USB port. There is no "ding-****" sound on connection. Plz suggest
Interesting solutionI have noticed. I shut down computer, then, connect drive, and turn on computer. Then after computer is up and running works great. BUT!! You should never go to sleep mode on computer without first Safely remove device! And every time you shut down computer you should Safely remove device. If disk fails again, just shut down computer, and connect drive, and start it again...
Oct 09, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I have just bought a Verbatim 4GB PinStripe USB Drive. My Windows 7 computer at home will not recognise it, and nor will most computers at work (Windows xP Professional). The shop replaceed it, but the...
Hello John,
The Store 'n' Go PinStripe USB Drive from Verbatim has a push and pull sliding feature which protects the USB connection when it is not in use without the need for a separate cap which is easily lost.
Aug 16, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
How do I format a Kingston 8-GB Data Traveler 101 flash drive which is write-protected?
You can try to go to safemode (to go to safemode restart the computer then tap F8 while restarting then select Safe Mode with Command Prompt) Note: you have to have the flash drive connected before restarting After loading files if your USB Memory Stick drive letter is (F) for example then write as C:\windows\system32>F: and press enter F:\>format F: and press enter If it ask you (Y/N) then press (Y) and press enter It should reformat the usb flash drive
You can also check out the registry under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
The value should be "0".
Jul 09, 2011 | Computers & Internet
I have two Verbatim Insight 500Gb external drives. I mistakenly unplugged them from my PC without pressing the option to remove hardware safely. It now only says scanning. No computer in my house will...
you may have to take them apart and put them directly in the computer to fix them and may have to reformat or fdisk them and format to use again but you will lose all the files. there are recovery programs out there but they are not free... there are recovery services out the that are very expensive (1200.00) good luck
May 20, 2011 | Verbatim 500GB USB Desktop 500 GB Hard...
My verbatim 4 GB memory stick does not show folders, only files after cleaning it of virus
this might be because the virus contaminated the folders and had to be removed either to the virus vault or removed totally
hope this helps
Apr 13, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
I HAVE 4 GB I-BALL PEN DRIVE. AFTER COPYING FEW FILES IT STARTED SHOWING "WRITE PROTECTED". NOW IT'S IMPOSSIBLE FOR ME TO COPY OR TO REMOVE ANY FOLDER FROM IT. HOW TO REMOVE WRITE PROTECTION?...
insert pen drive in safe mode. opern RUN from START menu. type : "FORMAT <drive letter>: /X /FS:NTFS" without quotes and press enter. drive letter is the pen drive.
Feb 24, 2011 | iLO (2 GB) MP3 Player
How do I safely turn off my Verbatim hardrive when I shutdown my laptop that it is attached to.
In the notification area you will see an icon with the Safely Remove hardware label - click on it; a small window will appear listing the devices connected to the USB ports (your stick included) . Click on the entry corresponding to the stick, wait a few moment to be unloaded from the Windows and take it out. Now you can shutdown safely.
Feb 06, 2011 | Verbatim VER95327 USB Hard Drive
Verbatim Model #USBPRO500 Shows up on list of
use the source (pc/Mac) that created the data to remove it.
you will need to re-format to get it to work on the machine you are currently trying to use.
(personally I always remove all partitions and format to "fat" (remove factory) this will make the drive work on Mac as well as pc)
hope this helps
Dec 14, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Bought a Verbatim 1Gb USB Drive with some .pdf files for secure zone. I overwrote these accidentally.
usb drives dont have manuals the computer automatically detect the drive.
in saving files it is the same when you save in a floppy or other drives.
Jan 31, 2008 | Verbatim VER95327 USB Hard Drive
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
