Question about Epson Stylus CX7800 All-In-One InkJet Printer
Double Printing when I print it looks like double printing I have done the align print head three times but no improvement
  • 1 more comment
  • pkorf100 Jul 21, 2008
    How do I check the drum
    I have done everything suggested and it still prints double
    I have done everything suggested and I have received the same ideas in every email and it still is printing double
    Brigadier General:
  • 6,966 Answers
Is the Epson CX7800 connected to the PC through a USB or parallel (LPT1) connection? Have you tried the printer in another PC and if yes, does the same problem occurs?
If you are using parallel, it may be necessary to go to the CMOS/BIOS setup of your PC and try the different LPT port selection, EPP, ECP, Normal and others available, Save and Exit and try again;
If USB, determine if it is indeed the printer or it is the printer's setting in your OS (by trying the printer in another PC).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 21, 2008
    Guru:
  • 1,894 Answers
No sir.
i think you need a manual cleaning of the nozzle holes.
  • dewan nafees ahmed Jul 21, 2008
    i too had a similar problem which got solved when i cleared the clogs of ink and a piece of plastic cover which i forgot to remove long back at the nozzle.
  • 3,037 Answers
Try cleaning the drum and checking it for excessive wear. Let me know how this works out.
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Jul 21, 2008
    Just take a cloth and wipe it down, it is the big black spindle that the paper rolls on when printed onto. If it isn't clearly smooth, then it may need replacing.
  • Benjamin Patri
    Did you get a lot of ink off of the drum?
    Did you recently replace the ink cartridges?
    Has anything been changed when this started happening?
  • Benjamin Patri
    Are both images perfect or does one seem very good and the other image just extra lines printed on the paper with poor quality?
    Genius:
  • 1,847 Answers
Run the head cleaning and aligin program.
  • Legin Varghese
    Legin Varghese Jul 21, 2008
    From the Start menu
    Follow the steps below to access the printer software.
    For Windows XP, click start, Control Panel, then click Printers and Faxes. (If the Control Panel is in Category View, click Printers and Other Hardware, then click Printers and Faxes.)
    For Windows Me, 98, and 2000, click Start, point to Settings, then click Printers.
    For Windows XP and 2000, select your printer, then click Printing Preferences on the File menu.
    For Windows Me and 98, select your printer, then click Properties on the File menu.
    The printer software opens.
  • Legin Varghese
    Click the Maintenance tab, then click the Print Head Alignment button.
    Follow the on-screen instructions to align the print head.
How to solve printing was double shaded
If you have one of those deskjet printers with two heads: black and color, might be that heads us unaligned.
Look ar printe's utilities.
In tnis case your printer has an application to align the two heads avoiding this "double shaded" effect.
May 02, 2015 | Office Equipment & Supplies
Why is my Epson WF 2530 double shadow printing?
Allen, that's very unusual. I've been using a workforce printer for years, and haven't ever seen anything like that.
What paper are you using, and what paper setting in your computer?
When you rand a nozzle test, were the nozzle lines even, or did some look kind of out of place? (a deflected nozzle will give that gosting effect, and "underhead cleaning" is the answer)
May 01, 2015 | Epson Office Equipment & Supplies
Tried printing double sided, will not complete job
Improve the FixYa experience for everyone by voting.
The first thing you should do is have Microsoft check your operating system for errors or inappropriate drivers. It only requires three clicks and it's FREE. You can give it a try by CLICKING HERE
Apr 29, 2012 | Canon PIXMA MX310 All-In-One Printer
My x3350 double prints text. It will overlay each sentence on itself. When I print worksheets on excel every other vertical line will be double-printed. I've tried to uninstall and reinstall the...
This may be a cartridge misalignment issue. First try printing with the settings changed to black and white print only. If this does not work then print in fast or draft mode (this should print in a single pass with less ink. Normal or best quality is usually done by passing the cartridges over the line twice.
Run the cartridge alignment test and see if it can be correctly aligned.
It could also be that the belt that moves the cartridge holder is loose and so two passes of the print head are misaligned. This may not be repairable (at least not economically).
Feb 20, 2011 | Lexmark X3350 All-In-One InkJet Printer
I have a Brother MFC-210. It was working well. When I moved and hooked it back up. It was printing some pages fine and then it started printing double like 3d. Started with a few words. Now the whole page...
Check the alignment. Press the key for Ink or Ink Management on the Control Panel. Select Test Print (the up/down arrows) and hit Menu/Set or Set. Select Alignment and press Menu/Set or Set. Next hit Mono (Black) Start. Look at the Alignment Sheet that prints out. Press 1 if the number 5 sample matches line 0 for both 600 and 1200 DPI samples. Press 2 and then the number for the line that matches that matches the 0 sample.
Then press Stop/Exit. Repeat this for color printing by using the Color button.
You should also check the Print Quality. (Very similar menu choices - just choose Print Quality after choosing Test Print but you only need to hit the Color button to print the test sheet.) This will initiate a cleaning cycle for any poor quality ink test pattern. You will need to respond Yes or No for the print quality and each ink (if you answered No). If you do the cleaning 5 times with problems, replace the cartridges in question.
Finally try cleaning the printhead (Press Ink or Ink Management and then 1 for cleaning) If 5 repeats do not help, contact Brother support, the print head may need to be replaced. (Unfortunately, this isn't the only reason for the problem. Once you put in a print head, it isn't returnable. It could be that the entire printer is ready for recycling.)
I hope this helps.
Jun 24, 2010 | Brother HL-2040 Laser Printer
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Double printing sometimes-HP DesignJet 500-800 series
When was the last time the heads were aligned? If that's not it, it's the belt.
Dec 17, 2009 | HP Office Equipment & Supplies
Aligning print head doesn't fix the printing
You only need to clean the encoder strip. The plastic strip behind the carriage assembly. Wipe it gently with a damp Q-tip and the double lines will go away.
Jul 20, 2009 | Canon PIXMA MX310 All-In-One Printer
My Brother MFC-465CN is printing text with alignment off and double text.
My Brother printer MFC-465cn is doing the same thing. I have workaround / worked-around it by disabling bi-directional printing. Then print is clear. It's as if the head is shifting an irregular amount on the opposite direction, like the head is loose.
Same for copies. If I use the PC interface to make copies, I can set the copy printing to be mono-directional, then copies are clear.
Sep 05, 2008 | Brother MFC-465CN InkJet Printer
Double printing
You need to re-align the heads of your printer... go to printer properties - then printer preferences - click on maintenance ... now align those print problems...
Oct 30, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus CX7800 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
