First I'm not a Kitchen Aid tech.
* The fan is stuck on or the cook cycle has not completed. Either way something is wrong. Try unplug the Micro wave and let it rest for 10 seconds. Power back up and see if the fan still runs. If so then pull the plug. Don't use the M/W
* Check your warranty and call or take it to the service center.
* There are no customer serviced parts in a Micro wave.
*** High Voltage present. High Gauss Magnets present, High voltage storage device hazard present even with power off and disconnected! ***
* Be safe, call for service or get a new unit and dump this one.
Aloha, ukeboy57
The "lock" function is nice if you have kids who like to push buttons. It disables the microwave oven to prevent it from running unnecessarily, To disable the lock feature push the "STOP-CLEAR" button. Then press and hold the "START" button until 'locked' is no longer shown on the display panel. To re-lock it, do the same thing until 'locked' appears on the display. Have a nice day.
usually when you kill the power and then when you put power back on the machine works it's the computer board that's bad.all you're doing is resetting the board just like your house computer,if something happens to it you shut it down and reboot it,that's what you're doing with the micro wave just rebooting the board.here's the funny thing about micro waves sometimes the part you're gonna change is almost the same price as a new micro wave so i would first check how much the board is,i went on sears and they have the board for 115.00 repair clinic for 235 part number WPW10216347 they don't make this model anymore but you can get a stainless micro for around 290 to 300 dollars and if you buy the same brand all you should have to do is remove the bolts up above that hold it in place and remove the micro wave and the same brand should mount the same way so you won't have to drill new holes or replace the back metal panel.if i were you i would replace the unit instead of the board repair clinic shows most of the parts for this model out of stock so it might be a while before you can get any parts for this model but this is up to you.good luck with your micro wave.one more thing when you were in there did you see alot of grease,this is usually the cause of no heat,the grease from cooking on the stove top gets into the micro wave and on the mag tube and damages it,if there was grease in there i would just replace the unit
Yes, take the rack out and recycle it. I do not know why these micro-wave
company put racks in the micro wave ovens. You get some insulation on the inside
the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come
out of the top inside the micro wave oven in a wave guide. Micro wave energy
that generation by the tube is high frequency into Gega Hertz. You have a metal
tray in side the micro wave acts like a big capacitor it stores energy in form
of heat the next you know it look like Marconi is putting on a lighting
display.
Leave the wire tie on a loft of bread and put in you micro wave oven to
defrost. The next thing you might see is a load bread burning, instant toast.
----The use of micro wave were invented by the British before WWII. The mega
tron tube generation very high frequency radio wave and these wave struck an
object 100 miles away some of this beam energy would balance back to a
receiver-----You have Radar.... I wish you and your family well being and be
careful of micro wave ovens it can burn from inside out. GB you...stewbison
your micrwave may run fine at 110 but it draws more power than the generator is putting out when the magnetron kicks on which is the part that creates the microwave causing the food to heat up. In other words the amperage is too low for the microwave. Amperage is what matters not voltage.
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running. A - This most commonly is abad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common. Q - My microwave is running and sounds like it is working but will not heat up anything. A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay..... Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food? A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
