Forgotten pasword Thanks for this. Before I try, can I confirm 2 things. Is the default password "default" and will defaulting to the default password impact on current wireless conections for other laptops?
    Guru:
  • 1,342 Answers
Default IP address: 192.168.2.1
Default admin username: <blank>
Default admin password: <blank>
It shouldn't impact your current connections unless you used different user IDs and Passwords for each connection.
Posted on Jul 21, 2008
I want to set pasword bt i forgot my old pasword. how can I reset again
A forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router. Press the reset button for few seconds then you can login using default username and password.....
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 22, 2012 | Computers & Internet
I forgot my paswordhow do i reset it
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Apr 19, 2012 | Linksys WRT54G2 Wireless-G Broadband...
What is the pasword for philips hdmi dvd player
In 'GENERAL SETUP PAGE', press 3 4 to highlight {DISC LOCK}, then press 2. LOCK Select this to block the playback of the current disc. Subsequent access to a locked disc requires six-digit password.
The default password is '136 900' (see page 41 "Changing the password").
UNLOCK Select this to unlock the disc and allow future playback. 2 Press 3 4 to select a setting, then press OK to confirm your selection.
hope this helps
Apr 17, 2011 | Philips DVP5140 DVD Player
I have forgotten my password
well go to your login page and click forget pasword and put your registration email then you will recieve a confirmation mail from the server.
OR
email to server's reseller that y forgot password then they will send you to reset pasword.
thanks
VPN Service
Jan 28, 2011 | Computers & Internet
Our Feature 983 Admin password was changed by mistake and doesn't work anymore and I tried the default one of 1020000 and it will not work either. How do I reset this password?
To reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000. 1020000 if you have 3 digit intercom numbers. Once that's done you can go into admin programming to default your password back to 0000.
Sep 10, 2010 | NorStar M7310 Phone
I forgot my pasword to get in to the router how do you reset it?
Reset the Router to factory default by pressing the Reset button for 10 seconds and then releasing it. If
you are still getting prompted for a password when saving settings, then perform the following steps:
1. Access the Router’s web-based utility by going to http://192.168.1.1 or the IP address of the Router.
Enter the default password admin, and click the Administrations => Management tab.
2. Enter a different password in the Router Password field, and enter the same password in the second
field to confirm the password.
3. Click the Save Settings button.
Regards..
May 20, 2010 | Linksys Wireless-G WRT54G Router
Menu pasword
The manual says:
You cannot enter MENU by forgotten password.
- If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to
the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button
and the "PTZ" button on the left for 5 seconds. The password default is "4321".
Jul 23, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Cannot reset to factory default
Try hard reset Hold the reset button for a minute and while you are holding the button, also unplug the power cable from the back every 15 seconds. So, you would unplug the power 3 times and make sure, dont release the reset button even when the power is unplugged. This works for most of the SOHO routers. cheers
Mar 14, 2007 | SMC Barricade g SMCWBR14T-G Wireless...
Computers & Internet Logo
661 people viewed this question
David Payne
David Payne
