Question about Fisher and Paykel GWL11 Top Load Washer
Lid locker The first solution you sent to me doesn't work.I checked the top lid locker and it 's look fine.Do you have somethingelses.please.Thank you
    Brigadier General:
  • 6,966 Answers
Hi again,
Appreciate much the "Ask Me".
I posted a rejoinder in your original post. Below is a copy...
"To fully determine whether the switch is defective or not, a continuitytester is required as well as access/removal of the said switch. This page would show you general idea of lid switches, while here would be an illustration of a generic approach to gaining access to lid switch of a top loading washer.
Another indicator would be a solid clicking sound if the switch engages but technically the continuity test would be best
Posted on Jul 21, 2008
  • Louie  Role
    Louie Role Jul 21, 2008
    A quick & dirty check if it is really the switch or not (and in the
    absence of a continuity tester) is simply (but temporarily) jumping / shorting the
    wires (two) that goes to the lid switch. The lid switch is a safety
    feature hence doing this procedures calls for knowledge of basic
    electrical circuitry and related safe practices when working with
    electrically powered devices.
Doesn't spin or agitate
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Aug 26, 2011 | GE WBSR3140DW Top Load Washer
This is a top loading washing machine. Initially, you may want to check the lid/cover ans see if it does not seat properly. There is a switch that has to be engaged when the cover is fully/correctly closed. If not, the switch will lit the warning light as you see it and prevent any further action from the machine.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 19, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washer doesn't go on (or fill) when pull out the knob. Fuse was replaced some months ago and when it stopped now we replaced fuse but it popped again.
Hello, Thank You for using FixYa. I will be helping you today.Check the lid switch there are two.Usually when the fuse blows it is connected with a failed lid switch.I always change them together.It is part number 12001514
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag LSE7806A Top Load Stacked...
Will not agitate or spin. Have replaced the belt (was worn) but still wont. Fills fine. When I first put the new belt on I ran it empty (stopped it when it started agitating, moved it to sping, stopped...
Thanks for choosing FixYa and welcome. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter. Thank you very much for reading this tip and thank you for using Fixya. As for the spinning, you need to check the lid switch. It may be bad. It may be your motor drive since it doesn't do both. Have you had draining problems?
Feb 23, 2011 | Maytag HAV3460AWW Top Load Washer
Ihave maytag stackable the dryer works but washer stoped with water in it now the washer will not do any thing. i checked voltage at the harness coming out of control button and i have 110 volts at the...
How many wires go into the lid switch?
If there's only two wires, short or connect them together and wrap the connection with electrical tape.
Then put the timer/programmer on the spin cycle and try if the water drains out and the machine goes to the spin phase.
If this works, then you have a defective lid switch/ lid locker
Nov 03, 2010 | Maytag LSE7806A Top Load Stacked...
When I try to use my cold cycle on the washer it wont work.
Dear Customer
Please perform the following checks
check the lid switch if the switch is broken the washer will agitate but wont drain or spin
Plaese rate this,Thank u
Dec 17, 2008 | Roper RAS8445KQ Top Load Washer
Maytag alantis MAV 9600
hi thanks for the question re set the water level control to see if it will add more water if it doesn,t it could be a bad water valve check that thanks the appliancedoc
Sep 06, 2008 | Maytag Atlantis MAV6000 Top Load Washer
I had this happen once and believe it is caused by an object in the DD not letting the inside top lid to close. The top lid needs to be reset. Simply unplug the power and wait 30 seconds or so and plug it back in. This should reset it.
Aug 26, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Oct 19, 2006 | Whirlpool LSR5132PQ Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
71 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
