Question about Garmin StreetPilot C330 GPS Receiver
Charging battery unit turns off as soon as I shut down car and takes a very long time to find sateilites
I have the same issue. I did a diagnostics and found an error code that says "Abnormal Powerdown". Im trying to charge it via my USB right now, but it hasnt held a charge and its been charging since 4pm (7hrs). Im having the same symptoms as you, and am told that when the battery is dead, other things dont work, even when plugged in. Its worth a shot. If not, you can get a new c330 for 120 on the net.
Posted on Jul 22, 2008
Model PL81. Why does it zoom, beep, and shut down?
Are you positive that the battery is good? Turning on for a few seconds and then shutting down is a classic symptom of a battery that did not take a proper charge and as soon as the surface charge is used, unit will shut down. And what if your charger is not properly charging the battery?
If you have a battery eliminator try that in lieu of the battery to see what happens.
Mar 28, 2016 | Samsung Cameras
Camera can't take photos
Most of the time, when a camera asks to shut down there is a problem with the camera. Could be the lens can't come out complete or other, almost invisible things. Even the battery can be a bit low, so as soon as it wants to make the camera ready to "shoot" the voltage goes low. Lots of cameras, will go off then. If you can't find any obstruction on the lens, please charge the battery and try again.
Nov 27, 2013 | Panasonic Lumix DMC-LS70 Digital Camera
Dead battery after turning the vehicle off, and trying to restart.
Pull the battery take it to any of the chain auto parts stores and have it tested, I bet the battery is no good.
Aug 31, 2017 | 1997 Oldsmobile Aurora
Ausus U50A power tansition problem
If you are saying your laptop shuts down when you remove the power cord then that's a sign that your battery is dead.
Batteries only have a useful life, then after that they have to be replaced. Once the useful life is up, most times the battery will not take a charge.
Some batteries will take a charge and say they are at 100% but as soon as you remove the power cord it doesn't take long before it is drained at 0%.
Jun 05, 2012 | ASUS U50ARBBML05) PC Notebook
Unit shuts down after about one minute.
When you leave a Nuvi on a charger for several hours and don't see full green bars, this is an indication that the battery is defective. Most Nuvi batteries last about 2 years. Most of the batteries have a date code of 2007. I would have the battery replaced as soon as possible as it can bloat and crack the case open. More info can be found here:
http://www.sharc.net/gps_battery_repair.htm
- Jim
Jun 01, 2010 | Garmin Nuvi 660 GPS Receiver
Camara shuts off as soon as it turns on. Lens
I believed that you are using the battery came from the box the KLIC-7004 which is very good. Now since the battery indicates its charge, first thing you need to do is to removed the battery and Memory card, Now wipe the 3 metal contacts of your battery then reinsert only the battery in your camera then Turn It On. If the camera shuts off try to used 5V AC adaptor to Turn On the camera, If this failed to turn On using the AC adaptor It means the camera needs of service call Kodak Tech support toll free 1 800 421 6699 ext 12
Nov 09, 2009 | Kodak EasyShare M1033 Digital Camera
1997 lincoln town car battery drain
Sounds like short ore you leave some dash lights on to drain the unit. If relay start to make you upset die hard made a battire that you could shut off like secuirty thing to shut down the power it cost 150 i dont know they still make it
Jul 28, 2009 | Lincoln Town Car Cars & Trucks
My unit will not turn on when i start my car
Change battery, or check charge wire if hard wired. i would think your battery needs complete change. The reason for delay is usually the fact that it has reached the end of its life and takes some time to build enough charge to drive the display. The power pull is greater than the ability to store, so that is why it shuts down
Jun 22, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Replace battery sign in New canon A590si camera.
You're using the wrong batteries. You need to purchase lithium batteries. They are quality batteries for high powered, battery operated electronics. Personally, I have a battery charger and use rechargable duracell batteries. (HR6/ DC1500/ NiMH/ 1,2V) Gives you approximately 16 hrs before having to recharge.
Dec 01, 2008 | Canon PowerShot A540 Digital Camera
Ique 3600
This is correct. If you want to use it all the time you will have to get a new battery.
Apr 17, 2007 | Garmin iQue 3600 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
80 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
