Question about Olympus Cameras
The camera won't turn on. When the power is turned on, the camera lens pops in and out 2 or 3 times before shutting down permanently. The power light does flicker, but the camera is rendered useless. Why??
I charged the battery 3 times, with no results. Then I banged the **** out of it on the counter top. It seemed to work after that! ...?
Posted on Aug 04, 2008
Lens seems to be stuck
It sounds TOTALLY CrAzY......trust me...I thought " are you serious?" when I read it BUT metallicachi is RIGHT!! I had the same problem where my camera would turn on, lens would ever so slightly pop out, three beeps and power down. Soooo, I tried what metallicachi had said to do. I turned it on, ever so lightly hit the lens on my desk as it was poping out and BAM.....instantly fixed. Use this solution at your own risk of course but I was desperate and glad I was cause I was just saved from having to invest money into another camera. Thank You Sooooooo Much metallicachi!!!
Sep 25, 2009 | Samsung S860 Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Lens Errors 17 & 27 on Sanyo VPC-E760
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Aug 03, 2008 | Sanyo VPC-E760 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Nikon Coolpix s200
I turned the power on and shook the camera on my palm, lens facing down. And out popped the lens!
Feb 29, 2008 | Nikon Cameras
Camera turns on then auto shuts down??
when the lens comes out grab it and lightly!!! push it to one side this worked on a cannon i have
Jan 22, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Cameras Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
