Lands Phones Logo
Posted on Jul 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Exhust if i take the baffles out of some after market pipes will it hurt the motor on a 98 650 yamaha v star like the back pressure the pipes are cobra stright pipes
Anonymous
Level 2:
  • Expert 97 Answers
  • Posted on Jul 21, 2008
Anonymous
Expert
Level 2:
Answers
97
Questions
0
Helped
35044
Points
251
Just make sure you rejet the carb all bikes come from the factory on the lean side to meet epa standards etc. if you dont rejet you'll actually lose some power and have nasty backfires as well take the time to put a jet kit in i personally recommend dynojet easy to install and comes with suggestions for your application
Can anybody tell me how to make my Vulcan 500 louder , do I drill out the baffles or cut the out , or do I buy after market pipes . the year is 2000
cutting or drilling can cause motor damage as this will lower back pressure change the pipes also will need to re jet carb best to ask dealer what else you may need to do or the manufacturer of the pipes will have info on your bike
Apr 08, 2015 • Motorcycles
2answers
1helpful
Will drilling holes in the stock pipes baffles cause any harm
Not at all Patrick. Just keep in mind that you do want
some back pressure and not all out "straight pipes" of
course....so start small. I'd say roughly 3/8".
And since I don't know the length of your baffle, I can't say
how many to drill.-but I have done this for a friend that was in need of help and I created my own baffle for him and it turned out great.
But in your case ,-Hypothetically speaking Let's say the baffle was
12" long...I would drill 3/8" holes, straight through and alternate
meaning sideways...then the next straight down. And I would drill every 3 inches.
I'm Guessing your looking for a 'lil more power and performance
and if you do it right, you can also increase the fuel mileage.
Please let me know how everything turns out, and on top of that,
Don't be afraid to first Build an exact copy of your baffle so
you can interchange " creations " till you get what you're looking
for.
Remember...the more exhaust that can escape the cylinder,
will help Pull more air and fuel into the cylinder.
1helpful
2answers
I have a 2006 road king classic and got samson 2 inch drag pipes slip ons with no baffles will it hurt the motor to run them with out the baffles
No it won't hurt anything as long as your pipes are long enough. If they're way too short, you'll burn your exhaust valves up. As long as the pipes reach at least the front of the rear wheel, you should be fine running it straight piped. It'll make her sound good too. You'll be pleased with the sound change
I busted out all the baffels in the stock pipes and was wondering what would happen if i didnt get the bike rejected. the bike runs good its just it back fires due to me busting the pipes out but i can...
baffles are on a bike for a dual reason one it cuts down on noise and the other real important one is proper back pressure your valves will get no commpression relief if the air can just escape to fast your bikes motor will get hotter faster damage depends on how your valves are set and the choice of spark plug you run i would say for your peace of mind if you want a loud pipe get power cones to give back the pressure your motor needs and then you can run a free exaust flowing pipe that back fire is your valves already going out of adjustment they are not closing right and extra air is sneaking in during the intake /exaust transition i hope this helps you
1helpful
REMOVAL OF BAFFLES IN A ROYAL STAR DELUXE
To remove you just find the spot welds that hold them in and drill them out or you can use a hole saw bit that just fits in the end of the pipe and drill out that way,But once removed you may need to adjust the carb and possibly the timing due to the lower back pressure on the motor,Without the adjustments the bike can run too rich or too lean and cause poor performance.(Although this don't apply to all bike,I just wanted to make you aware of the possibility)
6helpful
3answers
Backfiring when idling back down thru the gears
that seems to be what they do, i too have a 650a and have jardines on with baffles, it still pops and cackles when you roll off the gas. are you running no baffels? when i took mine out i noticed a drop in power as i had removed the requierd back pressure for optimum performance. you can get small baffles to slip into straight pipes from jc whitney for about $5 each.
anyway back to the backfire. my local bike shop shrugged their sholders when i asked them about mine saying it's what they do. you will get used to it and you will find a way to kinda not make it do it so much. i actually have grown to like it now, except when there are cops about.
happy safe riding
8helpful
2answers
Remove baffles from mufflers on a 1998 Suzuki VS 800 Intruder
there will probably be a couple or rivets close to the end of the muffler. drill out or chop off with a chisel. pull out baffles. but beware it will be loud. i did this to my dragstar/v star and ended up putting them back. you could just remove some of the fiberglass packing from the baffles, the cops will give you sh*t if you run straight thru. aftermarket pipes would be the real way to go, you may need to re-jet the carbs though. my bike also lost power with no baffles as engines need back pressure and all pipes are designed to give this.
hope this helps
Top Harley Davidson Lands Phones Experts
k24674
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
