My printer and scanner do not work. Both are canon
    Problem Solver:
  • 8 Answers
Please consider and remember when the printer or the scanner did work properly. Also give a moment to note what has happened recently, before the onset of the current problem. The record will help to continue to narrow down the likely cause or causes and most quickly arrive at the solution for this problem, for these two problems.
Perhaps you have a hardware problem with a hub that connects the printer device and the scanner device to your PC, but lets look at and try some very basic things to try to fix the problem before even pursuing any hardware repair or hardware replacement.
First start with basics. If you have recently added camera software and a USB camera or a Firewire IEEE 1394 cabled camera, remove the camera for this trouble shooting activity, to see and try to get the printer to work again. Leave the scanner disconnected too.
Start the computer. Check to see if the device is found and is identified correctly. For the printer, see if it appears in your list of printers. On a PC, see in the Start Menu, the item Printers, or Printers and Faxes. Move your mouse pointer over it and see what message may appear. Right click on the printer and select properties. See the condition of the printer. After you have right mouse clicked with your ring finger, click on properties. Let's start by getting your printer to work. Maybe locate your Canon software driver installation CD, or go to www.canonusa.com/support for the driver and download it, choosing to Save it to your desktop or into C:Temp or C:Downloaded Printer Driver - Canon (if you do not know how to select the destination folder, do not select Save, simply select Install. The advantage of save before doing install is to have the driver available to make a driver CD for any other trouble shooting or computer reload activity you may want to or may need to do, to get the printer working sometime again in the future.) The ways to fix the printer problem include first, simply disconnecting the printer, then reconnecting it to the PC, and checking to be sure the printer is powered on, is online, not offline, and is actually well connected properly to the computer. The next thing to try will either be to delete the printer from the Printers in the computer and then to readd the printer. The driver will be needed so it is very helpful to have the driver installation CD or the downloaded driver - it is necessary in many situations, but some printers have drivers included in the Windows 2000 or Windows XP Home or Windows XP Professional or Microsoft Vista operating system. Best to have the newest correct driver from the manufacturer website before deleting your printer, and then proceed to delete and readd the printer. Your printer may have a flashing indicator light, a blinking that you can match up to a solution in the printer user manual or printer operator manual or the printer manufacturer's printer troubleshooting and support website. The small display screen may indicate the printer is offline because of a paper jam or because the ink supply has run out. Resolve any problem with the printer. See if this fixes the printer problem. Then proceed to add the scanner, or disconnect and reconnect the scanner, or download the driver or locate the manufacturer supplied scanner software installation CD and drivers that are needed for your computer to run the scanner. Sometimes you will find that you can set up the printer and the scanner to work directly to the printer, and then after working properly, disconnect the cable and connect the printer USB cable to the USB hub. Do the same steps to get your scanner working with it connected directly to the computer, then try to connect it to the USB hub and shut down the computer and restart the computer, and see if all is resolved by these steps.
Posted on Jul 21, 2008
How i do scanner in canon ir2022
connect computer to network
install canon color network scangear, select printer ip in this software.
now you need scanning software.
I'm using freekapture.
place document in printer scanner. click scan button on printer.open freekapture and start scanning
Jul 06, 2012 | Canon iR 2022 Printer
Since upgrading to windows 7 the canon mf8180 printer is working but I can no longer use the USB connected scanner.
The Canon 8180 will work with Windows 7 32 bit operating systems only. Their latest ToolBox drivers will also get the USB connected scanner to function. 64 bit Windows 7 users are simply out of luck as the printer is not compatible. Drivers are on Canon's site and easy to access.
Dec 29, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
Canon printer problem
Scanner not work because printer need recognized both cartridges.In your case color cartridge is defective.Replace it and the message will disappear.
Sep 13, 2009 | Canon PIXMA MP180 All-In-One InkJet...
I can't get my canon MP510 printer to scan. Can
If you are pushing scan and then black or color and the scanner is not working then check to see if the scanner loaded whth the rest of the options. Click start, chose printers and faxes, choose scanners and cameras, right click WIA Canon MP510, choose properties, check status. If not active or not there, you will need to reinstall.
Jul 26, 2009 | Office Equipment & Supplies
I have pixma MP145. i want use my scanner corectly
you have to install the scanner driver & application in able to use the scanner to scan documents.
here is the driver for your scanner, download & install it.
Canon PIXMA MP145 Printer Driver 1.05 For Windows Vista(32/64)/XP
Jul 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Scanner not runing without printer cerdige
MP160 scanner cannot work when printer has trouble. fix the printer first.
Apr 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Scanner not working on Canon MF8180C
We had this when using the printer via network cables. The scanner only works with a USB cable and the setup orgram won't recognise until then.
Jun 02, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
167 people viewed this question
jasbo
jasbo
