You don't have a carberator on it, it's fuel injected. Id try spraying carb cleaner in the throttle while you have someone turn it over. If it fires up for a few seconds then dies then you might have a fuel pump problem or fuel filter clogged. If it still doesnt fire up then check if you have spark, if no spark see if your crank sensor is good and if your coil is getting power. If your coil is not getting power you might have a crank sensor problem. Try this and let me know if it helps.
