Question about Microwave Ovens
Maytag over the range microwave
Total loss of power while cooking, power comes back on after around 30 minutes and then will cut off agian while attempting to use microwave
  • Microwave Ovens Master
  • 9,086 Answers
First, is the internal cooling fan running when you cook?
The cooling fan (not to be confused with the hood / exhaust / vent fan) is critical to keeping the magnetron from overheating.
The magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
This can be due to a failed cooling fan or a failing magnetron.
One way to test this is to place a cup of water inside and cook on the lowest power setting for 2 minutes and see if it makes it all the way through.
Then try it again on full power.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
We even have a video on our site that shows you how to safely & easily remove the control panel assembly in less than 5 minutes so you can check out your oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
Micowave continues running after time is up
This can be two things that I know of 1 is a timer defect and the other is someone has placed some type of metal ie utensil, foil, can whatever into the microwave - either way you should replace the microwave and its a fire hazard to your home and others around you and the cost of a new unit is not worth the losses a fire can bring.
Jan 14, 2013 | Maytag Appliances Over-the-Range Microwave...
Maytag microwave cook delay - first minute on timer no heating, then works fine
Not a feature I've heard of.
I would do a hard reset by unplugging the oven for a minute or two, setting the clock, then trying again.
If it still does this, I would contact Maytag customer service at the number in the owner's manual.
Dec 25, 2012 | Maytag MMV6180WS Over the Range Microwaves
Mircoway stops after 5 mins of cooking
there wiil be some paint of the in side
Apr 29, 2010 | Maytag Over-the-Range Microwave
No power at display!
You've probably destroyed your magnetron, and the magnetron thermostat.
This kind of abuse will not be covered under warranty.
It will likely run about $75 for a technician to visit the home, $75 to do the work, $75-90 for the magnetron, and about $15 for the thermostat.
You can locate a Maytag-authorized servicer at http://www.maytag.com
Apr 24, 2010 | Maytag MMV4205 Microwave Oven
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Total power loss during use
Check the voltage on the outlet,make sure it is 115v -- 122volts max, any less will cause it shut off, make sure the polarity off the outlet is correct and it is grounded,check all of your wiring connections, if all this is ok replace unit with a different unit or different supplier of unit
Jan 26, 2009 | Microwave Ovens
Microwave losing power
Jul 21, 2008 | Maytag 2.0 Cu. Ft. Over-the-Range...
Maytag MMV5165BA Over The Range Microwave
We had this problem. It was installed improperly - to recirculate instead of to vent.
Sep 07, 2007 | Westinghouse WST3504 Microwave Oven
Shuts off after cooking a few minutes
Since it's under warranty, I would check with MayTag or a local Maytag-authorized servider: http://maytag.com/support/service_parts.jsp
Apr 23, 2007 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
60 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
