ASUS M4A79XTD EVO Motherboard Logo
Posted on Feb 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New build with asus M4A79XTD EVO and AMD Phenom II X4 965 Black Edition Deneb 3.4GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor. When you hit the power button, the fans start but immediately stop. Motherboard green light is on. Tried remounting the CPU to cooling fan system as suggested by ASUS with no change. Any suggestions would be appreciated.
Anonymous
Level 3:
Genius:
  • Master 1,400 Answers
  • Posted on Feb 03, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1400
Questions
Helped
392932
Points
4210
Hello
It almost sounds like a mistake at the pc start switch and reboot switch.
Check that you have your pc start wires from the front start button of the case, in the correct spot on the motherboard.
Also remove the memory sticks and reseat them.
The green light on the motherboard is good it means your getting power from the power supply.
The start and reboot switch wiring can be tricky if one plug is in the wrong spot on the motherboard.
ECC what is it
Error correction control or something. For memory sticks.
Desktop restart pc
It sounds like you need to upgrade or replace your power supply. How old is the power supply and what is the make and model number of it?
THIS MAINBOARD SUPPORT THIS PROSESSOR Phenom II X4 920 (2.8GHz, 125W, 2MB total dedicated L2 cache, 6MB L3
Motherboard,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=943&DetailName=Feature&MenuID=1&LanID=0
Processor Support (CPU Support),
AMD Phenom II X4 model 920, uses .0875 to 1.425 Volts, (DC),
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#.22Deneb.22_.28C2.2FC3.2C_45_nm.2C_Quad-core.29
That is the average voltage range for the AMD Phenom II X 4 processor.
Look back at the AMD Phenom chart again on Wikipedia, and look especially at the voltage range for the 900e to the 945.
Now look at the ECS CPU Support page again, and you'll see your motherboard supports Phenom II X4 processors from 900e to 945.
Since the 910e and the 925 are supported, I know the technology of the 920 is supported.
The Core architecture and nanometer technology it is based on, is supported.
No BIOS update may be needed.
Yes is the answer.
For additional questions please post in a Comment.
Regards,
joecoolvette
[NOTE*
That processor can use up to 125 watts of power. You need a decent Power Supply.
That processor also gets H-O-T!
Make sure it has a GOOD cooling system, and the computer case inside, and the Power Supply, inside, are kept clean ]
2helpful
Can processor AMD Phenom X4 9650 Quadcore to use motherboard Asus M4A78T-E ?
you cannot use m4a78t-e to amd phenom x4 9650 because it does not support am2+ socket, it only support am3,phenom II,sempron 100, and athlon II processor.
Can AMD Phenom X4 9650 Quad to use in motherboard Asus M4A78T-E ?
Yes your motherboard supports AMD Phenom X4 9650 Quad. However you need to make sure your BIOS verson is greater than 1503. if not you need to upgrade your BIOS.
Caution: Update your BIOS if its absolutely necessary and at your own risk. Wrong move may spoil your motherboard.
What is the best quad core for ax3400g-u4802
The best quad core for that computer would be the AMD Phenom II X4 980 Black Edition. It will fit in your computer's AM3 socket, and is outrageously fast. It will cost a pretty penny though, almost $200.
Here is a link for reviews and online purchase: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103934
How many processors in a computer?
There is ONE processor in any computer but each processor may contain multiple cores. Also each processor has what is called "cache" usually named L1, L2, and L3 with different speeds that corresponds to your processors speed. ( i vote go with AMD processors if you need one they are great with price and quality i have a phenom 955 x2 quad core and i LOVE IT 3.2ghz of speed)
1helpful
Hello again, Upgrading CPU's
Your board supports socket AM2 CPUs the fastest of which is the AMD Athlon 64 X2 6000+ dual-core processor at 3.1 GHz.
Your motherboard does not accept socket AM3 CPUs.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
