Texas Instruments TI-84 Plus Calculator Logo
A
Anonymous Posted on Feb 03, 2011
I have this different type of graph, it is onle showing the right side of my graph...I can only see the positive x axis. How do I change it to the full graph, where I can see the positive and negative x axis'
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Feb 03, 2011
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443521
Points
622693
Press MODE to bring up the mode screen. Use the arrow keys to highlight "FULL" on the eighth line and press ENTER. Press 2ND [QUIT] to exit the mode screen.
Hi, How do i find the upper bound on a casio calculator when the lower bound, the function and the area (integration value) are given?
Let us consider this to be math problem. From the physics point of view the units are inconsistent:thus the problem is ill-posed.
What you need it to draw the graph pf the function y=cos(t^2), then the integration feature of the calculator to calculate the integral between 0 and some upper limit, which will be found by trial and error.
Here are some screen capture to help you along the wayimage 1-kgpayaan5mwqlexbne0izpdg-2-0.jpg
Make sure the graph type is y=cos(X^2). Don<t worry the variable in this type of graph must be Ximage 2-kgpayaan5mwqlexbne0izpdg-2-1.jpg
Here is your graph.
Press SHIFT F5 (G-Solv) You see the following image
Press F6 (Arrow pointing right) to access the other features, as on the following screen:
You see the integral sign above F3: Press F3 to do integration.
Use the left Arrow key to move the cross on the graph to X-0 or just enter 0. and press EXE. This is the lower bound.
You need to enter the upper bound. Since you do not know where to stop you must try different values and each time, read the value of the integral. For example if you enter Xupperlimit=0.5image 9-kgpayaan5mwqlexbne0izpdg-2-45.jpg
the value of the integral is 0.45 (not 1)image 10-kgpayaan5mwqlexbne0izpdg-2-55.jpg
Repeat the process changing the upper limit until (if you are lucky) you hit an integral of 1.
Now a few more pictures
Getting close. Now I use the 1st zero of the function, x=1.2533 approximate
Getting close. However from that zero to the next the area under the curve under the x-axis is negative and there will not be a solution until maybe somewhere in the second positive part.
So you can accept the value of the integral from X=0 to the 1st zero (1.2533) to be about 1. Or you will keep playing the game. But as the next picture shows, you will not get a better approximation than at the first zero.
Good Luck.
How do you change the units on the x-axis to terms of pi?
The xmin and xmax values are the left and right endpoints (respectively) for the x-axis. In window settings type - pi and + pi for your request. At fist type diamond button and then F2 to get window menu
1helpful
When i type in a trig function to graph, the mode is set to radians but the calculator continues to use degrees. How do I make it graph using radians on the x-axis?
The calculator OS (the latest version) has 2 angle settings: Graphing angle and geometry angle.
In Graph mode, Press the menu button, then select Settings, set graphing angle to radians.
Here are some screen captures to help you.
Be sure to validate your changes by pressing OK
My TI-84 PLUS calculator wont show the graph after i type in an equation. please help!
You need to fix your graph so that it shows the correct y-axis and x-axis.
It works best if you press the zoom button and then scroll to find the ZoomFit option.
Then the graph should show up.
How to chang the size of the numbers
The title of the thread and the body of the question do not seem related. Or maybe I do not understand
A. Font size
If you want to change the font size in documents.
  1. Press the Home button
  2. Use arrows to highlight 8:system Info
  3. Press the Click button
  4. Select 2: System Setting and Press Click
  5. Use the tab key to highlight the Font size
  6. Use the down Arrow to unfold the menu and select Large
  7. Use the Tab repeatedly until you reach the OK button and Click or ENTER
  8. Accept the changes by pressing Yes.
Graph window ZOOM
If you have a graph and geometry document open (whether there is a graph or just the axes)
  1. Press the MENU button
  2. Select 4:Window
  3. Press Right Arrow to unfold the menu list
  4. Select the Zoom type
  • Window settings: You set your values
  • Zoom box: Select the corners of the box by moving cursor to desired position and press ENTER or Click.
  • Zoom In select center of graph and the graph will be redrawn
  • Zoom Out select the center
  • Zoom Standard :Standard window dimensions (default values)
  • Zoom Quadrant 1; restrict the graph to the first quadrant
  • Zoom Trig: When drawing trigonometric functions, dimensions are multiples of Pi.
  • Zoom Fit : The zoom is arranged to encompass all data.
  • Zoom square.
You can do certain manipulations by moving the cursor towards the axes. When the hand appears press Click/hand to grab. Pull out (away from an axis) or in (towards an axis). You can pull horizontally or vertically. The graph will react to the pull.
7helpful
Err: no sign chng
When you get the sign change error it is either that you have mixed up the left bound and the right bound or that you are marking the left and the right bound both above the x-axis or both below the x-axis. That's why you get the sign change error. Your range values must have different signs.
1helpful
11helpful
4answers
How to graph linear equation in two variables
I am not quite sure what you are asking...
(1) if asking for graphing y= -2/3x+2, then press [diamond] [F1: Y=] type in .2/3x +2, see graph by [diamond][graph]
(2) if asking for graphing y= -2/3x+a, where a=3x, then first archive a=3x in Home screen by [home], type 3x [sto] a, then go back to y= menu, and type -2/3x+a in Y1
(3) if asking for graphing an equation that is dependent on 2 variables at the same time, use x-y-z axis (aka, change mode to graphing 3-D by [mode]graph [5:3D]) then enter desired equation in y= menu using Z function in terms of x and y aka z(x,y)= ...)
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
