Question about Coby DVD-224 DVD Player
Power surge I had a power surge a few days ago and it blew a couple of resistors out as well as the fuse. Is there a schematic of the internals that I can download to make these repairs myself. This unit is out of warranty and if I can't repair it I will probably just throw it away. This unit worked great before the storm. Thanks Donnie
  • donnie072003 Jul 21, 2008
    I have already opened it up and determined which resistors are burnt but, they are burnt beyond recognition and I can't tell what resistance they are. Thanks for the promp answer though.
    Donnie
  • 537 Answers
I doubt you'll be able to find a service manual for this. You are best off opening up the unit to find the damaged resistors and replace them yourself.
Posted on Jul 21, 2008
40 amp. fuse keeps blowing out on 2008 harley
You have a short. Check the insulation on all wiring that carries + voltage - possible that some wire may have lost insulation and is abutting some metal part shorting it out.
Aug 24, 2015 | 2008 Harley Davidson FXCWC Softail Rocker...
Why does my fuse blow out when i turn the amp on?
sounds like you have a dead short internally and unless you find and fix it will continue to blow fuses .
Aug 02, 2015 | SWR La15 Bass Combo Amplifier
No power - blown fuse?
If it was run without the fan a thermal protect device was more than likely taken out. Check for that and replace the fan.
Mar 25, 2013 | GE Profile Spacemaker XL 1800 36"...
My VEA 42 inch TV is no longer getting power. Is it just a fuse or do I need to replace something els.
If there's no led light at the front panel of your unit, this is an indication that the power supply board is not working.
Please check the instructions below.
If you're unit is not under warranty period(if so, avail it because the manufacturer will fix it for free) you may open the back cover of it.
1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 30, 2011 | Televison & Video
Tv wont turn on
Check the ff:
1. Power plug - for open internal wire due to frequent bending,pulling.
2. Try to power by remote - if power up by remote then you have a faulty tack switch.
3. Replace Internal Fuse - sometimes because of power surge the fuse fail. However if the fuse blew again this is an indication of shorts.
Next step is not Diy because of the ff reason
3. Voltage regulator - might be open or shorted.
4. H-out transistor - shorted
5. Open fusible resistor in line with the B+.
6.Dry joints
Thanks for using fixya.
Pls rate my help.
Jan 25, 2011 | Hitachi Televison & Video
B212D powered speakers internal amps damaged by power surge in our home. Can they be replaced with new amps and what would cost be. johnssale@gmail.com
Cost by replacing the amps would NOT be cost effective.
In looking at the schematic, assuming there was a voltage surge on input power, possibly the diodes and capacitors in the power supply are damaged if the fuse blew and was replaced.
If the speakers were powered by a different receptacle than the source feeding the audio to these was, ground bounce may have destroyed the first input stage.
You need to give us current symptoms so we can direct replacement of bad components.
Dec 14, 2010 | Behringer B212D Powered Speaker (550...
Think Power surge blew out radio. Can it be fixed?
The fix may be as simple as replacing a fuse. Location varies by model, but each has an internal fuse on one of its circuit boards. SAFETY NOTE: It may seem obvious, but be sure to disconnect power from the set before you open the case.
If the fuse is not the problem, you will need to seek professional repair. Unfortunately, Bose does not release their parts lists or schematics, effectively creating a monopoly for parts and repairs. In fact, their web site says that the Bose factory is the only option for service or repair. They used to list a flat rate repair charge on the web site, but removed it - probably because it scared too many people. Their troubleshooting guide (below) might help, but it's very simplistic.
Before you invest in expensive factory repair on one of these trouble prone sets, you might want to investigate the new HD radios -- better sound at a MUCH lower price.
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/troubleshoot/index.jsp
Feb 09, 2009 | Bose Wave Radio
481 doesn't work
did that to mine. Bat went dead and went to jump the car. What happends is when you attach the jumper cables, it surges the power to the amp. This gets worse with caps. I would say you blew the relay in the amp and needs to be replaced. It is worth fixin but youll have to send it off or take it to a repair shop to have the new relay put in
Oct 05, 2008 | Nitro BMW-481 Car Audio Amplifier
Apple LaserWriter 8500 not turning on
There is a glass-tube fuse inside, near the power switch that blew on mine a couple of years ago. Being the curious type, I popped off the side cover to see if there was any obvious reason, loose connectors, burned resistors, etc., and found the blown fuse. Can't remember where I got the replacement, but think it was Radio Shack. It's a common type.
Dec 12, 2007 | Apple LaserWriter 8500 Printer
Washer WM-2277HW and Dryer wont turn on after power outage.
there is a fuse on the control board but it is soldered in place and cant be changed. whole board needs to be changed
Oct 19, 2007 | LG WM-2277HW Front Load Washer
Coby DVD-224 DVD Player Logo
78 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
