Question about RCA MM36100 36" TV
My rca television works fine exept for the sound
When i turn it on everything else works but the sound doesent it a 36' model mm36100.
  • dtxleblanc Oct 31, 2008
    tv is on but no sound
There is a switch on the back of the TV that toggles between the built in speakers or the external speakers. Try flipping it and see what happens.
Posted on Oct 24, 2008
SOURCE:
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Rca mm36100 power problem
Try a hard reset to this set first. To make it hard reset, unplug it from AC mains wall socket, and re-plug it back after 20 minutes or so. If this do not help you, the main system memory IC has to be replaced. This is not a costly part, but replacing it is a skilled work.
Aug 16, 2012 | RCA MM36100 36" TV
Good older rca tv favors blue green, red is weak. tint function doesent help this problem is there an adjustment inside?, where, turn down green blue or turn up red? jm
Hello; The red probably got low over a long period of time due to only one thing. The CRT/ Picture tube is getting weak and cost much more than the set sold for. The adjustments may only help a little and the set will get worse. These adjustments are done on your remote control with service menu accessed. You will need a Service Manual for instructions to do this, but I think it's time for another set. John
Apr 25, 2011 | RCA MM36100 36" TV
Cannot get audio to come on
Obvious first just in case, check mute and volume level. Make sure all cables are secure, each set of volume connections is tied to a particular view setting. go through the different inputs and see if sound is tied to a different input. Try hooking up another sound device and seeing if another device gets sound. (an I.pod can even be connected via a 3.5mm cable.)
Go through all this troubleshooting and you may solve your problem and learn some things about your monitor.
Note, In audio Properties there is an option to turn speakers off, make sure to verify that as well
Dec 27, 2010 | RCA MM36100 36" TV
I have a MM36100 RCA TV. It has glitches/screeched and shut off. It still has not turned on. What normally happens in this scenario?
This particular set can have failure in many circuits and have the same screeching sound and not
power up. By design, it is a difficult set to service. If this set has a DVR built in, it was a common problem for the capacitors in the stand-by power supply to fail. It would be located on the left side of the chassi on a narrow board. The capacitors tops will be bubbled or popped if they are bad. That was the easy fix if your set has a DVR in it. If not, the High Voltage or the Horizontal output transistors could be bad. To gain access to the bottom of the set you will need a nut driver, I believe it was a 5/16. Also look for any loose solder connections around any of the high voltage components or transformers.
That is all I have,
I hope this helps,
Skyassoc
Nov 24, 2010 | RCA MM36100 36" TV
Hi im having a problem with my RCA tv. The problem is that when i turn it on I can hear the sound put there is no picture. Can anyone help me with this problem of mine.
Power supply regulator section inside your tv has some sort of trouble. It doesn't starts. We cannot predict the exact resaons for this kind of problem. There are so many reasons. It can be rectified only with the help of a technician. You just go for an experienced technician, or inform your nearest authorised service center for your tv.
Oct 16, 2010 | RCA MM36100 36" TV
1999 RCA mm36100 TV The buttons on the front panel are all messed up sometimes they work and sometimes not. The menu keeps popping up from time to time randomly and sometimes runs though the menu items all...
Bad push button board, best thing to do is just unplag the board and use remote to operate TV, board is mounted under front cover where button are.
Aug 09, 2009 | RCA MM36100 36" TV
No Sound
Hi Brickey,
These RCA televisions are notorious for this problem. You will need to have a technician change a chip called the EEPROM which holds the memory settings. The memory gets corrupted and the chip needs to be replaced or reprogrammed by unsoldering it, removing it, and inserting it into a device. After this is done it can be reinstalled and your sound will return.
MyTvGuy
Jan 23, 2008 | RCA MM36100 36" TV
Rca tv mm36100
There is a common problem in this unit with R14103 (33k 2watt ) resistor that opens. When open SMPS will not load so no other voltages beyond the 5v source to click the relay.
Another possibility is the Horz. drive transformer, RCA p/n# 243859 board location T14451.
Either of these possibilities are inexpensive fixes reletively speaking, so I would advise having it estimated by a qualified shop for repair..
Bill
Nov 24, 2007 | RCA MM36100 36" TV
RCA MM36100 color problem
sounds like you have a deguassing problem with your TV .. have the repair person bring out a deguassing coil and see if thsat helps.. This will only be a temp repair as you will have to have the problem that caused this to be fixed. good Luck
Aug 12, 2006 | RCA MM36100 36" TV
RCA MM36100 36" TV Logo
89 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
