Question about LG Washing Machines
I have an LG Tromm2277HW washer. I am unable to open the dispenser, the door appears stuck. Any ideas about how to get it open? Thanks PLease respond to lsekhar@aol.com
  • lsekhar Jul 22, 2008
    It is the door for the compartment in which one loads the washing fluid, and the fabric softener, not the dorr to the compartment where you put the clothes...
    Genius:
  • 1,665 Answers
    Sergeant:
    Champion:
  • 347 Answers
Hello Lsekhar,
Please Visit the link on our webpage where they clearly explain how to solve door jams.
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Good luck,
Dahaka
Posted on Jul 21, 2008
  • Santiago Vallejo
    Santiago Vallejo Jul 22, 2008
    lsekhar,
    I cant find similar problems to your online.
    The problem isnt stated on LG's weboage, nither on the product manual.
    However you should try some simple tricks as using a knife as a lever. Place the knife between the dispenser and the washer. Then soflty apply some pressure. Dont try to hard as you can break teh knife, the washing machine, or even injure yourself.
    This is just a quick solution you should try.
    If that dosent work, you should call a repair service near, or call LG at this phone number: 1-800-243-0000
    Or email them at
    customerservice@lge.com
  • LG Master
  • 13,433 Answers
The washer needs to be idle for around 20 minutes, turn the washer on if its off. make sure there is no program. so its just idle / ready. It should open up in 20 minutes up to a hour if not, there may be a fault in the door mechanism.
  • 1 more comment
  • Ekse Jul 21, 2008
    Someone has suggested to hit the door lock, Im not sure if that is good advice or not, try at your own risk.
  • Ekse Jul 21, 2008
    Hitting the door / lock would work only if the Door interlock is jammed
    possibly - Door catch, handle, or mechanism broken
    or - The water hasn't pumped out properly and the washing machine has a pneumatic door safety lock which wont let you open the door.
  • Ekse Jul 21, 2008
    also if noting has yet worked - Many front loading machines have to be fully off, as in the dial is on off and pulled out (or pushed in) whichever is the direction for "off."
My AWOE8748 had a fault code F13. It has now switched itself completely off.
F13 indicates "Dispenser Circuit Error" in your washer.If the dispenser motor is not able to be driven to it's proper position this error code appears.Check mechanical linkage from dispenser motor to the top of the dispenser. The wire harness connections to the dispenser motor and Central Control Unit (CCU) would have been faulty so check for those.Also do a final check on dispenser motor.
Thank you !!
Jun 20, 2010 | Whirlpool AWOE8748 Front Load Washer
Stuck Water/Ice Dispenser LG LRSC26920TT
THE ACTUAL BUTTON AND ACTUATOR NEEDS CHANGING AND POSSIBLY THE SWITCH. EARLIER MODELS WERE CHANGED BECAUSE OF THIS.
Aug 18, 2009 | LG LRSC-26922 Side by Side Refrigerator
Code ddo
Hi
This error code appears in the frigidaire washer which means--
ddo error--- Dispenser Drawer Open
Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing. The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself, you will see snapping clips to unsnap, then you will see the magnet#8 in diagram#1 here:
GLTF1670AS0
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 08, 2009 | Washing Machines
A string from one of the clothes got stuck in the lock mechanism and the door won't unlock
If the door fails to unlock after 11 attempts, you will see the "LO" code. If this was caused by foreign matter infiltrating the latch area try this. Open the dispenser lid and look for a plastic cord tucked away towards the front. It's the same as "weed whacker" cord. Grasp this cord firmly and pull it from right to left (away from the latch). This is the emergency cord to open the door after a latch failure. remove any debris that would hamper the operation of the latch assembly. Close the door and try going into a spin cycle to check the door lock operation.
Apr 29, 2009 | Maytag Neptune Washer
Detergent dispenser stuck
Had the same problem here today, the softener dispenser blue plastic piece was loose jamming the whole dispenser tray, to resolve remove top cover, two screws on top rear, slide the cover towards the back, you will then see the detergent dispenser, press the right clips and pull it off slightly at the back; do not put too much pressure and try to remove the cover completely, just pry the plastic cover a bit then pull the detergent tray it should come right out.
Apr 07, 2009 | LG WM-3677HW Front Load Washer / Dryer
Water coming out from detergent dispensor drawer
Is this an HE2 washer? if it is, open door gently tug at bellows top left hand corner you should see a small piece of clothing stuck between tub and dispenser inlet to the tub.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Cant open soap drawer on washer
I opened up the top of the washer by unscrewing the screw in the back. then I pressed down hard on the white plastic cover of the soap dispenser that you will see on the front left hand side of the machine. I also moved it slightly to the right by pushing on the side of the same unit.
The soap dispenser then opened up fine. I cleaned out the soap dispenser from any crud that developed in it. Now it opens and closes nicely.
Did you know there is a class action lawsuit against LG for mold that develops inside of this model washer? I joined in the lawsuit. There should be no mold accumulating in any washer.
Sep 07, 2008 | LG WM-1485FHD Front Load Washer
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
My detergent/softener pull out drawer is stuck!!! need help please!
This problem has just started popping up for me as well.  I believe that the problem is in the dispenser assembly where the drawer slides into.  You will have to pull hard and possibly may break a part of the plastic drawer to open it.  The dispenser assembly looks like it is bowing in the middle and jamming up against the dispenser drawer.  If it jams up like that, you may need to replace both the drawer and dispenser assembly togther.
Jan 06, 2008 | LG WM-3677HW Front Load Washer / Dryer
LG LFX29560 Ice Dispenser
You may need a service call as the ice dispenser flap is operated by a solenoid which is controlled by a small pwb board which is located by the dispenser.
Sgt 48
Nov 30, 2007 | LG LRFC25750 Refrigerator French Door
Washing Machines Logo
74 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
