posted by sheri714 on Jul 21, 2008
Actually my remote is a RCR311W. I didn't know the color changed the number. And I still cannot find the "Code List". Will you PLEASE help me by sending me a usable link to find the "Code List"? The link I tried to go to earlier won"t load. I feel like someone thought it might be fun to keep the "Code List" for this particular remote control device a secret. Well, it's not funny anymore and I would really appreciate being let in on the secret. Thanks
Best Solution
posted on Jul 28, 2008
Manual Code Search and Entry 1. Manually turn on the TV
2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for RCA RCR311B Remote Control
Email this problem
Email this problem
Can you Help with these Remote Controls problems?
remote will not change to input...
My remote is like the 311B... Answer This...
remote exits Auto Code Search
Every time I pushed a button... Answer This...
Repair Service
Find Remote Control Repairman Near You:
Find Parts
