Question about Samsung CLX 3160fn All-In-One Printer
Transfer belt error
Where is the OPC drum?
To the left of the color cartriges. It is light gray shaped sort of like an L and beside the cyan (blue) cart is a finger lift just pull out and Clean.
Posted on Aug 06, 2008
Thank you both! I just pulled the L thingy off and put it back on. No cleaning because I didnt want to hurt it, it belongs to the company I work for. Make sure you turn it off and then back on though!
Posted on Aug 22, 2008
Thank you everybody! Thank god for the internet!
Posted on Aug 29, 2008
Thanks for this it fixed the problem after I switch it off and on again. Make sure you got newpaper around it makes a horrible mess.
Posted on Aug 18, 2008
Is it the opc?
THIS IS THE OPC DRUM COMPLAIN PLEASE REPLACE THE OPC DRUM &WIPER BLADE .
Mar 15, 2014 | Samsung Office Equipment & Supplies
OPC Belt reset
Sir/Madam
I suggest You watch official video In Brother Printer Official Website For Your Brother Printer Issues:
How do replace thebelt unit With Video Instruction Brother
I Hope You Resolve Your Brother Printer Issue and Brother Printer Problem By Now,
Or
In case You still need Brother Printer Help assistance Then I suggest You Follow Us On For:
Brother Printer Support
Nov 07, 2012 | Brother OEM Brother OP4CL OPC Drum Belt...
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
Tally t80063 service error 9
The SVC E9 error on the 8008 indicates a 'Belt Marker' error.
Basicaly the printer is not detecting the OPC belt rotating.
Check the OPC is not damaged, in particular check the left side of the OPC there should be a black squair that trips the light sensor which detects the OPC belt rotating. Check there is no damage here.
Locate the belt mamarker sensor, and clean it, this is on th left side of the pritner towards the top near the drum cleaner I think. It reflects of the left side of the OPC belt.
Check the OPC belt is turning, there could be a motor / drive problem.
Sep 16, 2009 | Tally T8006e Laser Printer
I have a 'service call 17h' error condition and was about to use some FixYa instructions that worked last time but this time i am unable to get past first-base, i.e. i cannot remove the OPC drum cartridge...
open the front door and remove the waste toner bottle and transfer belt. use a flat bladed screwdriver in the small hole at the 10 o'clock position of the hole where the toner cartridges are installed. this now allows you to rotate the toner carousel slightly to free the OPC drum and remove it. you will probably find that a toner is not in its slot correctly and jammed against the drum causing the error 17h. use the release mechanism to rotate the carousel and remove all of the toners. check them for any damage, also the OPC drum, power up the printer and refit the parts as requested on the display, being very careful to put the correct toner in the correct slot.
Aug 07, 2009 | Konica Minolta magicolor 2300DL Laser...
Error message svce 9 what does it mean ?
Jul 16, 2009 | TallyGenicom 8008 Laser Printer
TALLY GENICOM 8008
The SVC E9 error indicates a 'BELT MARKER' error.
This means the printer is not detecting the OPC Belt as rotating.
This error can be caused by a damaged OPC belt, you can check this by removing the OPC belt from the printer and look at the OPC belt it should have a smooth green coating if there is damage to this belt it may cause this error.
The error can also be caused by a damaged 'Transfer Belt' when the OPC belt has been removed from the printer look inside the printer where the OPC belt used to be located you should see a black belt towards the back of the printer, if this belt is damaged it can also cause the error.
Ensure the OPC Belt locates in the printer correctly.
If the OPC belt and Transfer belt look to be free from damage and a are located correctly in the printer you may have a faulty belt marker sensor or faulty OPC belt.
You can try substituting the OPC belt for an alternative one if you have this available to see if you can narrow the problem down to the sensor.
Jan 23, 2009 | TallyGenicom 8008 Laser Printer
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Transfer belt error
Transfer belt error, this is cause by the OPC drum which connects the belt. Make sure the drum sit well with the belt else replaced the drum.
Jan 29, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
522 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
