Question about Maytag Microwave Ovens
My over the range microwave just lost power during the middle of re heating something. after about 30 minutes, it cam back on but has continued to do the same thing.
  • Maytag Master
  • 9,098 Answers
First, is the internal cooling fan running when you cook?
The cooling fan (not to be confused with the hood / exhaust / vent fan) is critical to keeping the magnetron from overheating.
The magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
This can be due to a failed cooling fan or a failing magnetron.
One way to test this is to place a cup of water inside and cook on the lowest power setting for 2 minutes and see if it makes it all the way through.
Then try it again on full power.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
We even have a video on our site that shows you how to safely & easily remove the control panel assembly in less than 5 minutes so you can check out your oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
GE Profile microwave # nm1851dm2bb lost all power while heating something. Could it be the internal fuse? Anything else?
If you're lucky it's the internal fuse. Otherwise, there's not much other stuff besides the fan that's easily replaced.
Nov 25, 2013 | GE Profile Spacemaker Over-the-Range...
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Ge jvm1540dm2ww over the range unit: have a gas range and the fan on the above mounted microwave once in awhile turns on automatically while something is cooking on the range below it....
The heat sensor in the electronics panel senses the rise in heat from the stove below. Once the amount of heat reaches a certain level, the cooling fan turns on to keep the electronics inside the microwave cooled.
I wouldn't worry about it. mine does the same thing.
Jun 19, 2009 | Microwave Ovens
We have a frigidaire microwave and in the middle of cooking, the motor stopped. The clock and cook time continued to work, but no heat. We've tried using at half power, on defrost, etc. but nothing seems...
What you are saying the microwave stop work like heating,but but the clock counts down.If it is stop heating then there is a rest on or near the magtrogron.Once it cools down it start back heating.Open and close the door will reset power to the magtrogen{sorry about the spelling].Look for loose connector,or replace the click zon it should have a small red buttom on it.
Mar 18, 2009 | Frigidaire Over-the-Range Microwave
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic Model nn-s252bf.....not heating probably
check magnetron related circuit, any loose contact is there the above problems comes to oven, thats why check all wiring at high voltage section...
Oct 28, 2007 | Panasonic NN-S254BF Microwave Oven
Microwave Ovens Logo
63 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
