Question about Northgate Computers & Internet
I have a Northdate computer and every time I push the front button to turn it on it would shut right back down. I opened the side panel and took out the power supply box and replaced it. Still doing it also the wires going from the button to the side board I took off but then relized at the button it wont come off went to plug back in and I dont know what order now.This is what the plugs say. Power SW, HDD LED, PLED-, PLED . How do thay go now?
    Problem Solver:
  • 6 Answers
Ok find the pin on the mother board of your pc you will see a 9 pin like this ( ::::. ) or in reverse order just put the pw sw. in pw mark you can see that just read it
Posted on Jul 21, 2008
Trying to locate the fuel pump shutoff switch
In the trunk. Drivers side by where the trunk lid hinge meets the body. (just below) most of the time there is a door on the trim. you push the button down on the top of the box. It is round and wont look much like a button but it is.
Jun 23, 2014 | 1999 Ford Taurus
Printing problem hp D7160 error 0xc18a0001 please help
Hi,problem can be solved .Please check out this link for the Ink System Failure problem.
fixyourownprinter.com/forums/printer/39471
These are from the link above:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate.
Our HP 3310 was having the same ink system failure. Tried everything I could find, and had just about given up when I found this forum. I didn't quite get the reset right the first time, but on the second try it worked. After holding down OK, Cancel, Black and Color buttons while turning it off, I turned it back on, it turned itself off and I turned it back on again, it started off doing the calibration and it took about 5 minutes, but when it was finished I had a working printer again.
Also
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
Hope this works for you. Please let me know.
Oct 28, 2010 | Office Equipment & Supplies
After a minor impact on my passengers side door my 02 Ford Focus will turn over but not start
Hi Mackenzie_me,
There is an inertia switch on this car.When there is a big enough impact,the switch will open up to shut down the fuel pump. This switch is located on the panel on the base of the "A" pillar on the passenger side. Or the panel where the right foot of your front passenger would be. You will see a small cut out that will allow you to push the reset button. Give this a try,let me know how it turns out. Chuck
Feb 28, 2010 | 2002 Ford SVT Focus
Cant open the case to my HP pavilion 700
First, turn off the PC, remove the power cord from the back of the PC to remove the 115 volts then push the power button for a second or two so the capacitors will discharge. This is important because the residual charge can cause Motherboard damage especially when changing the RAM. You should follow this process ANYTIME you enter the PC case to make changes, etc.
To remove the side panel on a Pavilion 700x series:
Only one side panel allows access to the inside of the Pavilion case, the left side if looking from the front of the PC. The left side panel has knurled thumbscrews, not machine screws. Loosen the thumbscrews, they are designed to stay attached to the side panel, place your hand on the middle of the side panel and with inward force push the panel towards the back. The panel will slide and inch or two and you can pull it free. This proccess is easier if the PC is unplugged (push the power button on the front of the PC after pulling the power cord to dischard the capacitors) and the right side of the PC laying on the floor. This allows easy access to the left panel and allows light to enter the case from above to change/add the RAM you want to install.
Apex44
Mar 03, 2009 | HP Pavilion (PN153AAR) PC Desktop
I have a e-machines,when I pushed in the starter button it stayed in and cap came off. Now I can't shut it off. Who do i call to fix. I shut my computer when not in use. Please help, Thank you
My name is ArmyMason this isn't a big issue and it can be fixed. If you have a screw driver open the case by removing the screws in the back. if the computer is running tell it to shut down if it wants to boot back up pull the plug. Now with the case off, the front panel has clips on the inside of the case all you have to do is pop off the front panel. Pop out the button, the switch to turn on the computer should be attached to the case where the button is suppose to line up with on the panel. If the button is broken just leave it out put the front panel back on and put the case back together. Now see if you can turn on the computer without the button. If you cant reach it try poking something small in there to push the button. If you want to replace the button, I would check ebay or craigslist for a replacement case, they should be cheap. Also you dont nessessary need the exact model as long as they look the same it should fit.
Hope this helps,
ArmyMason
Feb 24, 2009 | E-Machines eMachines Desktop PC
I have a Gateway 300x Micro-Tower case circa 2002 and I can not open the case, without breaking it. I'm trying to install a new audio card and can't get at the 300x innards. Help!
Most of these towers are vertical style, therefore the big button is just to the left of the Gateway symbol. Push it in and pull the left panel away from the case.
Jan 11, 2009 | Computers & Internet
Hit clean button while oven door was open. now door will not shut and stove doesn't work.
I had the same problem . I opened the door after pushing the clean button.
The locking bar was sticking out and when I tryed to shut the door the bar struck the door approxmately 1/8'' past the right side of the locking slot in the door ,
I finally used a screw diver to pry the locking bar back about 1/16" I then lifted on the left side of the door handle forcing the door to the right I then I was able to pushed the door closed with my right knee. After I got it shut I pushed the clean button and set it on 3 hrs. At the end of the cycle and the cool down time the locking bar retracted and the door opened . Ever thing is back to normal.
Nov 28, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Hi I cannot get my d.v.d drive to open and close. What do I do?
  1. If the keyboard has a CD/DVD Eject key, press it. The Eject key is usually placed by the volume knob and is marked by a triangle pointing up with a line underneath.
  2. Double-click My Computer .
  3. Right-click the icon for the CD, CDRW, or DVD drive that is stuck, and then click Eject.
  4. If the CD or DVD drive door button is a long clear plastic bar on the front of the PC, press firmly on the right side of bar. Some models have a button on the front panel of the PC to the right of the hinged door. Press the button to eject the drive.
  5. If the drive door button is part of the PC case and is covering the actual drive door, open the door that is part of the PC case and press the Eject button on the faceplate of the drive.
  6. Restart the PC and press the Eject button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD driver. Try shutting down or configuring any software programs that create discs or monitor the CD or DVD drive.
  7. If the door still does not open, do the following:
    1. Close all programs and shut down the PC.
    2. Unplug the power cord from the power outlet.
    3. Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. The location of the manual release hole will vary
  1. Straighten the paperclip and insert it into the manual release hole until resistance is felt.
  2. Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
  3. Remove the paper clip and gently pull out the drawer until the disc is accessible.
  4. Remove the CD and turn on the PC.
If the tray still does not open, do the following steps to check the power cable for the drive. Work on a hard flat surface over a non-carpeted floor:
  1. Turn off the PC.
  2. Unplug all power cords from the back of the PC.
  3. Press and release the Power button on the front of the computer.
  4. Remove the side panel.
  1. Unplug the power cable and wait five seconds.
  2. Find a different power cable that is not being used, plug the different power cable into the back of the drive, making sure that it fits firmly into the socket. If a different power cable is not available, replug the original power cable into the back of the drive, making sure that it fits firmly into the socket.
  3. Replace the side panel and plug in the power cord.
  1. Turn on the PC and press the eject button on the front of the drive.
If the optical drive does not have the manual eject feature and the CD tray will not open by using the steps in this document or if a disc has shattered inside the drive, the CD, CDRW, DVD drive may need to be replaced.
Thanks
Aug 18, 2008 | Computers & Internet
My power suply have been pushed away from the right position and I want to open the computer to put the suply back to the right position. but how can I that. I can't find a special manuel for opening the...
dear ,
you can find nuts at side edge of back plane you have to unlock that first then do push side panels towards back side if your cabinet cd drive panel is front of you.
you will do...do with care.
May 15, 2008 | Acer Computers & Internet
Computer shuts down but does not turn off
Mchem, you actually have 2 separate issues going on there.
  • Open control panel > open the system control panel
  • in the system properties, click on the advanced tab
  • in the startup and recovery section, click the settings button
  • In the startup and recovery dialog box, under system failure, remove the check from the automatically restart option
  • click ok
  • click ok
  • Open control panel > open power options
  • in the power options properties, select the advanced tab,
  • in the power buttons section,
  • When I press the power button on my computer: click on the drop down menu and select the shut down option
  • click ok
Sebastien123, you only need to run the first part of this solution.
Dec 20, 2007 | EliteGroup ECS PF5 EXTREME...
Computers & Internet Logo
96 people viewed this question
Top Northgate Computers & Internet Experts
Lee Eismann
Tom Chichester
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
