When i run a systems check i get one problem that is never repaired. it say: (default)=C:WINDOWS\system32\macromed\Flash\Flash9b.ocx What does this mean and how can I correct it
  • 80 Answers
Hi im wesley. you need to uninstall macromedia flash player and re-install it that should fix it. the error is just to let you know that one of the files for macromedia is corrupt and not working.
Posted on Jul 21, 2008
I'm running windows 7 on a Toshiba L455 and I keep getting a prompt that says; can not find "flash.ocx"
Flash is a programming language that many publishers use to create animations, games, and interactive programs for the web. Flash is also used for programs run locally on a users computer. To use these Flash based programs and web applets, the end-user must have Flash Player installed. One component of Flash Player is a file called "flash.ocx." If this file is missing or damaged, you may get an error message.
There seems to be two root causes of this error. A description and solution for each follows:
  • You receive the error message "Cannot find the file flash.ocx" every time you start your computer or each time you open your web browser (such as Internet Explorer). This is usually the result of a missing "flash.ocx" file caused by an incomplete installation of Flash. Here's how to remedy the problem:
    1. Download the Flash Player uninstallrom Macromedia. Save it somewhere convenient.
    2. Run the downloaded program and allow it to finish.
    3. Once the uninstall completes, restart your computer.
    4. Visit the Flash Player website and download/install the latest Flash Player version.
    5. That's it!
  • You receive the error message "Cannot find the file flash.ocx" at seemingly random intervals or when starting a specific program (other than your web browser). First, perform steps 1-4 of the previous solution. This will insure you have the latest version of Flash Player installed. If you still receive the error message, continue with the steps below:
    1. Navigate to the folder "C:\WINDOWS\system32\Macromed\Flash\". In this folder you will see a file named "Flash9f.ocx".
    2. Make copy of the "Flash9f.ocx" file in the same folder as the original (copy the original, then paste the copied file into the same folder).
    3. Rename the newly made copy to "Flash.ocx".
    4. If the previous steps don't eradicate the error messages, change your screen saver to one of the defaults that are included with Windows (such as "3D Text").
if the problem still persist please let me know.
Apr 15, 2011 | Computers & Internet
Puppy kyn library not registered?
I had this same problem, i think at has something to do with windows 7, but you can change it to run in xpxp compatibility mode.
1) right click the icon for puppy grows,
2) go to properties
3) click compatibility tab
4) click/check box saying(run this programme in compatibilty mode for xp)
5) Open puppy grows icon and it should now work
Hope this helps
Grimmster
Jan 01, 2011 | Fisher Price Puppy Grows & Knows Your Name
After downloading the software for the Puppy Grows and Knows your Name by Fisher Price is says "Library not Registered" I have no clue what to do now. Any suggestions?
Install it in compatibility mode, Win XP Service pack 2 with administrator turned on (Right Click, Properties. Click on "Compatibilty" tab. Select Run this program in copatibility mode for: WINXP SP2. Under Priviledge level, select "Run this program as administrator). Then after it installs, do the exact same thing for the shortcut.
Sep 14, 2010 | Fisher Price Puppy Grows & Knows Your Name
Unable to delete files from HDD
You can use a file shredder, many are available free of cost or may your antivirus must already support this feature.
Apr 14, 2009 | Microsoft Windows XP Home Edition
How to register ocx on vista
[Solution # 1]
Drag and drop it onto regsvr32.exe in Windows\system32 folder. Make a shortcut for regsvr32.exe in the same folder the OCX is in and drag and drop it that way
[Solution # 2] Just run cmd.exe as administrator and try again. This is the key.
Here, step by step:
1. find the folder of cmd: it is usually on C:\windows\system32\cmd.exe
2. Do right click over cmd.exe and click on "run as Administrator"
3. now just use regsvr32.exe as you used to do!
For example, to register most Blackd Proxy ocxs, you might need to type this in "Administrator" cmd:
regsvr32.exe c:\windows\system32\richtx32.ocx
regsvr32.exe c:\windows\system32\comdlg32.ocx
regsvr32.exe c:\windows\system32\mswinsck.ocx
regsvr32.exe c:\windows\system32\msflxgrd.ocx
regsvr32.exe c:\windows\system32\msinet.ocx
regsvr32.exe C:\windows\system32\comctl32.ocx
A side result for Visual Basic 6.0 users: this seems to be the way to use components in Windows Vista properly. Just register the components of your proyect with "Administrator" cmd before adding them to your proyect (or before opening a proyect that already had such components)
[Solution # 3]
use this in command line
REGSVR32 /V then ur ocx or dll name
ex:
REGSVR32 /V CRPAIG32.DLL
[Solution # 4]
right-clicking the batch file and selecting
'run as administrator'.
richtx32.ocx
comdlg32.ocx
mscomctl.ocx
dxtmeta2.dll
Good luck
Mar 03, 2009 | Microsoft Windows Vista Ultimate Edition
Can't get Adobe Flash Player 9 ActiveX.exe to download.
Flash player 9 is actually not the latest version. If you want to install the latest version which is version 10, follow the steps below:
a. Download the most recent Flash Player uninstaller to your desktop from the TechNote below. Please read the instructions in the TechNote before running the uninstaller.
How to uninstall the Adobe Flash Player plug-in and ActiveX control
http://www.adobe.com/go/tn_14157
b. Quit ALL running applications, including all Internet Explorer windows, other browser windows, AOL Instant Messenger, Yahoo Messenger, MSN Messenger or other messengers. Check the Windows system tray carefully to make certain no applications which might possibly use Flash Player is still in memory.
c. Open the following folder: C:\WINDOWS\system32\Macromed\Flash
d. Run Flash Player uninstaller.
e. Check if there are files left in the folder: C:\WINDOWS\system32\Macromed\Flash. If there are any files left inside the folder, delete the files.
f. Download and install the latest Flash player at:
Flash Player 10,0,12,36 Active X (for Internet explorer)
http://tinyurl.com/67twte
Flash Player 10,0,12,36 Plug-In (for Firefox,Netscape,Safari,Chrome,etc)
http://tinyurl.com/8nz9s
Feb 03, 2009 | 2000 Ford Windstar
My PC internet connection is disconnected after 2-3 minute.
Here's some steps that worked for me in instalilng Flash player:
Please follow the steps below for uninstalling and reinstalling Flash player:
Jan 29, 2009 | Macromedia Studio MX 2004
I have a total video player but can't start
Flash is a programming language that many publishers use to create animations, games, and interactive programs for the web. Flash is also used for programs run locally on a users computer. To use these Flash based programs and web applets, the end-user must have Flash Player installed. One component of Flash Player is a file called “flash.ocx.” If this file is missing or damaged, you may get an error message.
  • You receive the error message “Cannot find the file flash.ocx” every time you start your computer or each time you open your web browser (such as Internet Explorer). This is usually the result of a missing “flash.ocx” file caused by an incomplete installation of Flash. Here’s how to remedy the problem:
    1. Download the Flash Player uninstaller from Macromedia. Save it somewhere convenient.
    5. That’s it!
  • You receive the error message “Cannot find the file flash.ocx” at seemingly random intervals or when starting a specific program (other than your web browser). First, perform steps 1-4 of the previous solution. This will insure you have the latest version of Flash Player installed. If you still receive the error message, continue with the steps below:
    1. Navigate to the folder “C:\WINDOWS\system32\Macromed\Flash\”. In this folder you will see a file named “Flash9f.ocx”.
    2. Make copy of the “Flash9f.ocx” file in the same folder as the original (copy the original, then paste the copied file into the same folder).
    3. Rename the newly made copy to “Flash.ocx”.
    4. If the previous steps don’t eradicate the error messages, change your screen saver to one of the defaults that are included with Windows (such as “3D Text”).
Fixya!
Chris (ziraffa)
Jan 11, 2009 | Adobe Photoshop 7.0 for PC
Could not find flash.ocx
download the latest version of flash from www.adobe.com and you should be good to go.
May 24, 2008 | ASUS P5PE-VM Motherboard
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
