Question about Maytag M7DH45B2A Dehumidifier
I have a DE50P Always dry dehumidifier. It runs for vawhile, and then freezes up. It just startted doing this. How do I stop this from happening? Jim Rogers jamesrrogers2@aol.com
I dumped this piece of garbage and bought a new one from a company I trust at half the price I paid for this DeLonghi piece of ****.
Posted on Jul 21, 2008
Why is my dri-eaz drizair 1200 dehumidifier freezing over?
There are two major causes of a dehumidifier or air conditioner to freeze up the evaporator coil. First is lack of air flow try cleaning or replacing the air filter if it has one; make sure the fan is running and the coils are clean. Second is a low charge of refrigerant requiring a refrigerant leak check; repair and recharge. A slight overcharge will keep a dehumidifier from freezing in cooler ambient temperatures.
Sep 25, 2014 | Dehumidifiers
Tip
Dehumidifier is Freezing up and not working
If you are having problems with your dehumidifier freezing up them here are a few things that you can check and also a few things that may help you.
First check the ambient temperature of the room at the level of the dehumidifier. If it is below 65 degrees and you do not have a special low temperature dehumidifier then you are asking for trouble. Most units are only designed to work in temperature 65 or higher and will freeze if they are working at lower temperatures. Some even will not work well below 68 degrees F.
Many dehumidifiers will shut off when the coil starts to freeze to let them thaw, then they will restart when the coil is warm enough again. This can take an hour or so. Some will not shut down the compressor and when the dehumidifier coil starts to freeze it reduces the air flow and only compounds the problem.
Check the air flow over the coil. If the coil becomes dirty or the fan motor stops or even slows down a bit, you will get freezing. The dehumidifier is very dependent upon the proper amount of air going over the coil to keep the coil warm enough to not freeze. Any restriction will cause problems.
The final and worst thing that can happen is for your dehumidification unit is to develop a slight leak in the refrigeration system. This will cause the coils to run even colder then they would normally and this will create the same problems. If everything else check out then you may have to have the refrigeration system checked by a professional. The problem with this is that many of these units only cost a few hundred dollars and a service call can soon add up to more then the unit is worth.
Some things that you can do to help out a dehumidifier that is freezing up are:
Raise the temperature of the room and provide a bit of heat for the room as the dehumidifier is actually a very small A/C unit.
Raise the dehumidifier up off of the floor… the air is usually warmer when you go higher up in the room, hot air rises.
Clean the coils off so that the air can flow through them easier and keep them warmer.
Make sure that the fan motor bearings are oiled and that the fan is running freely. Even a tiny bit of resistance will slow the fan enough to make a difference.
By checking all these things out and making some small changes you maybe able to make your dehumidifier work much more effectively.
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
on Apr 30, 2010 | Dehumidifiers
How do I change the air filter
To remove the filter:
1. Turn the unit OFF & Unplug it from the wall receptacle.
2. Remove the water collection bucket and set aside.
3. Just inside the water collection bucket holder at the top, you should see the a plastic frame
behind the front louvers of the unit. It may have a plastic pull tab. That's the filter.
4. Pull it straight down and then remove it from the unit.
5. Wash it in warm water and mild dish washing liquid. Rinse thoroughly and dry thoroughly before
reinstalling it. The filter should be cleaned regularly. NEVER operate the unit without the filter in
place. As this can cause damage to the unit.
Hope this helped you. Please let me know. Thanks.
Jul 08, 2011 | DeLonghi DE50P Dehumidifier
Goldstar Dehumidiflier coil freezes
Hi, If you are having problems with your dehumidifier freezing up them here are a few things that you can check and also a few things that may help you.
First check the ambient temperature of the room at the level of the dehumidifier. If it is below 65 degreesand you do not have a special low temperature dehumidifier then you are asking for trouble. Most units are only designed to work in temperature 65 or higher and will freeze if they are working at lower temperatures. Some even will not work well below 68 degrees F.
The final and worst thing that can happen is for your dehumidification unit is to develop a slight leak in therefrigeration system. This will cause the coils to run even colder then they would normally and this will create the same problems. If everything else check out then you may have to have the refrigeration system checked by a professional. The problem with this is that many of these units only cost a few hundred dollars and a service call can soon add up to more then the unit is worth.
By checking all these things out and making some small changes you maybe able to make yourdehumidifier work much more effectively.
Aug 11, 2010 | Goldstar DH504EL Dehumidifier
My dehumitifer freezes up shortly afer being turned on. Why?
This can happen if the Temperature in your room is too low. You can work around it and place a 40 watt bulb near the the inlet of the humidifier to warm up the air a bit. Also if the humidity level in your room is already too low this can cause your dehumidifier to freeze up.
Jun 11, 2010 | Eva-Dry EDV300 Dehumidifier
THE UNIT RUNS BUT DOES NOT EXTRACT THE MOISTURE
  1. There is no water being produced.
This can happen if the air is very dry and no water can condensate from the air. Check the coils to see if they are cold to the touch, actually they should be very cold, like almost freezing. If not then the refrigeration system of the dehumidifier has gone bad. To repair that you will need a person certified to work on refrigerant systems with specialized equipment. In many cases the costs to repair the refrigeration systems will more than the cost to replace the whole unit.
This should give you a brief overview of the problems that you can have with a dehumidifier and some of the things that you can do to help get things working.
Apr 18, 2010 | Kenmore 54501 Dehumidifier
Runs good but doesn't take any moisture out of the air
it is not running correctly if the refig circuit is not freezing the water out of the air. Check for compressor operation
Aug 10, 2009 | Whirlpool AD50USS Dehumidifier
My Whirlpool dehumidifier AD50DSL is icing up at the radiator. Why is this happening? How do I stop this?
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
heatman101
Apr 26, 2009 | Whirlpool AD50DSL Dehumidifier
Dehumidifer stopped collecting moisture, blows air w/ empty tank
Possible cause it's out of gas.
you might have to get a refridgeration mechanic to regas it, or/and fix any gas leaks
Apr 02, 2009 | Maytag M3DH30B2A Dehumidifier
Danby Dehumidifier Model # DDR557HE Serial # 0107030704369 --Does not collect water and cxontinues to frost up
Take care
Mar 23, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Maytag M7DH45B2A Dehumidifier Logo
108 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
