Question about Kenmore 33464 / 33465 / 33469 Gas Single Oven
F30 oven won;t come on and
My oven only beepas and flashe err and f30 when I try to turn it on
  • Anonymous Mar 29, 2014
    frigidaire model ples399ecd
    Scholar:
  • 191 Answers
Since how long are you getting this error ?
Posted on Jul 21, 2008
  • Moses Clive
    Moses Clive Jul 21, 2008
    hard reset the unit, unplug it from the power source for 2 hrs and then turn it back on. tell me the status ?
  • Moses Clive
    It could be the thermal cutout switch which will be reset and should operate in normal status.
I HAVE A F30 ERR DISPLAY ON BOARD AND THE DOOR IS LOCKED. HOW DO I RESET AND GET DOOR OPEN?
Hello Friend, this is Z. I am happy to assist you!
If you are getting an error code F30 on your Frigidaire range, it usually indicates an issue with a faulty sensor probe or a wiring harness between the sensor probe and EOC (Electronic Oven Control). You may try and reset your range by disconnecting the power or by flipping the circuit breaker off and back on after 10 minutes. This often clears most false error code. If the error code does not clear, most likely the EOC of your range will need replacing. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Aug 05, 2014 | Frigidaire Ovens
PLES389ECH F30 ERR code. Oven and stove top is locked out after trying to run self clean. The fan is still running. I have turned breaker off and back on after waiting a day and range is still locked out....
This should help, good info includes links! http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/76555-error-code-f30.html
Oct 27, 2013 | Ovens
F30 err flashes on the board. Can't get it to bake or oven to come on.
If your oven is made by Frigidaire, the F30 error indicates a problem with the temperature sensor, wiring, the controller or the thermal reset. You will need to check the resistance at various points and replace parts as needed. There are actually 3 sensors in series on one model, with the reset switch under the sensor near the 12" burner. On this model the resistance across each sensor should be around 1100 ohms.
Please add a comment with the make and model for more information on finding the sensors.
Jan 01, 2013 | Ovens
My Oven is displaying a f30 ERR message and won't allow me to use my oven,,,the stove works fine....what do i do?
I have same problem, displaying a f30 err message and does not work oven rest is working. I have changed sensor still does not work.
Apr 17, 2011 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
My oven gives an error code of F30 and the door lock flashes?
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Nov 16, 2010 | Frigidaire FEB30S5D Electric Single Oven
Frigidaire professional stove, Oven does not work, can't bake, self clean. get an ERR F30 code.
Is the clock set?
In mine - the clock has to be set - or it won't work;
Aug 12, 2010 | Frigidaire Ovens
What is F30 error?
Range made by Frigidaire, cannot pull up info right now for that F30 code, just the F3 which means something is wrong in the sensor circuit, sensor, wiring harness or the EOC/clock...what does your tech sheet tell us this F30 means??? What was the ohm reading on the old sensor.....if changing this did not solve the problem about down to checking the wiring harness, if it is ok back to the clock causing the problem if the F30 pertains to the sensor circuit failure....
Oct 14, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F30 ERR message on Frigidaire Professional Series Range
I am a tech and just had this happen to me, so I can feel your frustration. I have replaced the temp probe, erc, and still had the problem.
Open the back, with the unit unplugged. On the lower right hand side there is a relay, beside the relay there is a "safety T-stat" disconnect from the circuit by removing one wire and read for continuity. If none is detected, replace t-stat and voila... stove works. Much cheaper than erc and probe...
Jun 11, 2009 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
F30
My kenmore gas range displays F30 when I turn the oven on
Jul 21, 2008 | Kenmore 33464 / 33465 / 33469 Gas Single...
F30 ERROR
F30 error every time I turn the oven on
Kenmore 33464 / 33465 / 33469 Gas Single Oven Logo
276 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
