PC WILL NOT BOOT NORMALLY OR IN SAFE MODE - Computers & Internet
  • 1 more comment
  • ldk137 Jan 22, 2009
    tried to install memory board, but the board did not fit the slot as far as indentation on bottom of board. put computer side on and plugged in. Computer starts up but is in sleep mode.
  • 2real Feb 06, 2009
    my dell optiplex 520 it will come on to see the blue dell sign, but won't continue to boot, after it shows that in goes black
  • Peter VanderStoep
    Peter VanderStoep May 11, 2010
    So what does happen?
    Please to tell us what kind of system it is. What happened just prior to the system stopping normal function, if known.
    Scholar:
  • 47 Answers
First you have to check what kind of system it is. If the system is based on windows, then you have to check your BIOS settings of you PC.
Then check about your windows booting files, that are helpful to load windows.
Posted on Jul 21, 2008
How do I turn off safe mode in a Huewai y511?
Typically a computer that boots up does not come up in safe mode. You have to press the F8 key as the computer is booting up. If the computer comes up to a screen, and it is highlighting safe mode, use the arrow keys to select Normal boot mode. Press enter, and your computer will boot normally.
May 05, 2015 | Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
We have desktop xp and it is running on safemode how do we take this off
You can't take off Safe Mode, it's there for your protection. However, if you want to boot into Normal Mode, shut down the computer. When you hear the computer beep, start tapping F8 on your keyboard. Keep tapping it until you reach the Advanced Options menu. Once you've reached this, just select "Start Windows Normally".
Now it will boot you into Windows on Normal Mode, not Safe Mode.
Jan 01, 2011 | Computers & Internet
I set the normal mode to safe mode,but i dont know how to change back now
This happens when set you PC on Safeboot Option.
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then then ok.
6: Now your computer will boot in Normal mode.
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don't show this message again. You are all set.
Dec 15, 2010 | Computers & Internet
Remove safe mode
1. You cannot remove Safe Mode, it comes a boot profile on every computer running Windows, At the start-up menu you can always select the normal boot option to boot normally...
I hope this was the safe mode you were referring to...
Nov 17, 2010 | Computers & Internet
My computer is in safe mode and want to exit out of safe mode how do i do it?
5: Uncheck it then click on apply and then ok.
Nov 15, 2010 | E-Machines eMachines Desktop PC
Actually when i log on the computer then show the normal mode,safe mode etc.But when we press normal mode then donot open operating system. so whats the problem?
i think your os files may have been corrupted. first try to boot in safe mode. if it works then reboot and the next time if menu comes select normal mode.
normaly if safe mode boot succeed, then in next boot it will not ask for anything, the windows boots normaly.
Feb 19, 2010 | Microsoft Windows XP Professional for PC
Can't boot to safe mode
continuesly press F8 key before the OS boot.
then you will see the list of options,
the first option will be the safe mode.
select that option, it will boot the system ito safe mode.
dont forget to vote
Nov 16, 2009 | Acer TravelMate 2423WXCi Laptop
HOW DO I TAKE MY HP PAVILION DV6000 OFF OF SAFE MODE. BECAUSE THE PC CUT OFF CAUSE OF LOW BATTERY. I JUST WANT PC TO BE BACK IN REGULAR MODE NOT SAFE MODE
You should just have to shut it down in safe mode and reboot. And it should come up in normal mode. You can try hitting F8 when you turn it on until you get the boot menu and then select boot in normal mode.
If it keep wanting to go into safe mode it may need to reboto a few times to clear out something before it behaves but it should boot into normal mode on its own.
Oct 24, 2009 | HP Pavilion dv6000z Notebook
My pc only boots in safe mode, not normal mode. How do I fix this?
after booting the safe mode, try to restart the PC to run in the normal mode
Jul 22, 2008 | Computers & Internet
Computers & Internet Logo
274 people viewed this question
David Payne
David Payne
