Question about Whirlpool AWM6120 Front Load Washer
Whirlpool AWM8121 ?door open? light flashing and washing machine won't start. I had solved this same problem over a year ago. It seemed to be the door locking solenoid not working. I solved the problem by shorting out two terminals on the door locking mechanism which tricked the machine into thinking the door was permanently closed. (Not recommended). Now the same problem is back again and I can?t find a solution. Once pushing the Start button the machine makes noises for about 10 seconds then stops with the ?door open? light flashing. (The ?drain? cycle works though)
  • 2 more comments
  • foxyfoxyg Aug 03, 2008
    exactly the same problem
  • Anonymous Nov 30, 2008
    My whirlpool model number awm8123 has the same problem. How do I get to the door switch? Can anyone give me advice please
  • Carmen Mikulic May 11, 2010
    hi there,
    sounds like you have a door latch problem. the door latch contains a mechanical door switch, which can fail from time to time.
    can you provide me with complete model # please?
  • David Graham
    David Graham Jan 27, 2017
    8121 door light problem. Checked brushes-worn but OK.Removed door lock mechanism, jiggled contacts and re-assembled. Problem solved.
    Problem Solver:
  • 4 Answers
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Posted on Dec 13, 2008
I had the same problem with the 'door open' light flashing and machine won't start. My electrician found a broken wire (door lock) in the wiring loom fastened to the underside of the washer bowl. The wire tie was fastened too tight from manufacture and wore through from the movement of the washer bowl. Soldered the wire and problem fixed.
Posted on Mar 30, 2009
    Sergeant:
  • 409 Answers
just wondered if you fixed your problem.
thanks.
Posted on Sep 26, 2008
  • 3 Answers
Thanks Glenn, same problem checked for info and saw your post. Checked the brushes, sure enough worn out. Replaced them and its now running fine. Don't know how the "door open" light ties into it!
Posted on May 03, 2013
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
I had the same problem with AWM 8121, replaced the door interlock (AU$32) and it made no difference.
Got a tip that it could be the motor brushes worn out, .... and they were.
Replaced the main motor brushes (AU$50) and the machine came back to life, good as new.
Conclusion: When motor brushes wear out, machine stops with Door Open LED blinking (even when the door is locked). Real clever (not) design by Mr Whirlpool !! .... so they can sell door interlock switches?
P.S.: To replace the brushes, remove the rear cover and you'll find the motor near bottom LHS. It is secured by 1 bolt and is easy to remove after removing the belt (a bit tricky to put the belt back on). The brushes are visible and easy to replace (just remove 2 screws for each brush, no need to dismantle the motor)
Posted on Oct 15, 2015
Apparently.. according to my morning of googling, the door locked light also flashes when the brushes need a clean.. or replacing?? Can anyone confirm this?? If so, how do I get to them please??
Posted on Jul 25, 2013
  • 1 more comment
  • SUSAN BLAKE Jul 25, 2013
  • Daryl Jul 27, 2013
    Yes Susan . The light flashing also means the brushes on the motor are worn out.They need to be replaced. Fairly easy job if you have some mechanical skill. There are two they are held into the motor by screws. You can access them by taking the back off the machine.
  • Dan Finbow
    Dan Finbow Jul 28, 2014
    I have a whirlpool awo/d5446 changed pump as that was full of water!! Changed brushes on the motor as they were used up, now when it tries to spin up to speed it gets so far into the highest spin and the lights flash like there's a short circuit and appears to start the cycle all over again
I have a Whirlpool Cbrio top load washer. it won't start it's cycle. Once it senses the load, the lock lid light flashes and it does nothing. can this be fixed?
I would say that the lock has failed. Either the lock itself or maybe the pin or latch that fits into it when you close the door may have cracked / broken. If the machine thinks the door / lid is still open, it wont let you start it.
Jan 03, 2015 | Whirlpool Washing Machines
Where to put washing detergent in Whirlpool AWM8121?
Simply place detergent into wash ball and place inside drum on top of clothes,,,,fabric softener goes in smallest compartment in tray
Jun 20, 2013 | Whirlpool Washing Machines
Whirlpool AWM8121 says Door is open and will not wash. Is it Microswitch of something else.
Let'[s hope that is it.
These switches are made of plastic, and are really cheap.
It should be fastened with screws to the inside of the top of the machine, which you will need to open to access.
Be blessed.
Apr 20, 2013 | Whirlpool Washing Machines
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
Whirlpool AWM 8143 - Starts a cycle and then starts flashing open door light and won't go further. Door is shut properly. Tried turning it off at the power and back on to no avail.
This is either a problem with the door lock itself or most probably a motor failiure as the door open light also indicates some kind of motor problem. If your appliance is 4/5 years and above then you will most likely need to change the set of carbon brushes on the motor and this will solve your problem
Jan 18, 2011 | Whirlpool AWM8143 Front Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWM8121 stops working mid cycle. Bottom two lights flashing on spin speeds.
Fault code 3 = Drain failure or not detecting empty drum.
Check pressure switch, blocked drain, drain pump.
See link below for service manual.
http://www.user-manuals.com/advanced_search_result.php?keywords=857081253000&forward=plist
Oct 24, 2008 | Whirlpool AWM6120 Front Load Washer
AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool AWM6120 Front Load Washer Logo
5,872 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
