Question about Lexmark X1270 All-In-One InkJet Printer
All in one printer x1270 lexmark
Installed printer after restoring my computer - printer says its ready and it printed a test page - however unlike before i restored my computer - the all in one center page is not coming up on my screen nor is it listed in my programs - all thats showing up is the lexmark sulotion center which now i cannot use the scanner or make copies - you need a screen for that?
can you help
thank you
  • wanisefar Jul 24, 2008
    I have the same problem.
    installed printer after restoring my computer - printer says its ready and it printed a test page - however unlike before i restored my computer - the all in one center page is not coming up on my screen nor is it listed in my programs - all thats showing up is the lexmark sulotion center which now i cannot use the scanner or make copies - you need a screen for that?
    can you help
    thank you
  • ndube2 Aug 09, 2008
    I was able to do everything with my Lexmark X1270(scan, print, etc.) before I wiped out my computer and started from scratch. I installed everything I needed for this printer to work again. It'll print, but it won't scan. I'm running Windows Vista and never had a problem till now. What seems to be the problem here? Any suggestions?
    Sergeant:
    Champion:
  • 236 Answers
The "All-In-One Center" program is corrupted. I've also had this problem.
You have to download and reinstall the program from here.
Just select your OS (Windows XP) and click download.
*Note: here's the mistake people make a lot. Unplug the printer cable from the computer before opening the program. THEN when the installer TELLS you to connect the printer, do so.
Posted on Aug 05, 2008
Printer write as javascipt
I presume you are using the Lexmark X1270 inkjet printer since you're posting under this model.
It could be that the printer driver on your computer is not properly installed. Try to uninstall your existing printer driver then reinstall using the X1270 driver on the Lexmark website. To uninstall, from your computer, go to Start menu > Programs > Lexmark X1200 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.
When the computer turns on, please visit the Lexmark website to download and install the Lexmark X1270 XP Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Try to print your document again to verify that the problem is fixed now.
Nov 22, 2011 | Lexmark X1270 All-In-One InkJet Printer
My lexmark X1270 Printer is only printing in colour ......wont print in black
It could be that your black cartridge needs cleaning or is not properly seated in the carrier. Open the printer cover and reseat the black cartridge. Close the printer cover. Open Lexmark Solution Center on your computer. Go to Maintenance tab and select Clean to fix horizontal lines. Your printer will then print a test page forcing ink through the nozzles and clean them.
May 31, 2011 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 : scanner buttons have not responded since installation from new (except page feedthrough) Finally after updating drivers, still no response. What am I missing please in the 'how to do?'
The scanner and copy buttons function only when the printer is connected to a running Windows computer in which the proper Lexmark printer software is properly installed. The copy and scan functions are not available in the "free-standing" mode unlike, for example, higher end HP all-in-ones which can operate independently as copier, scanner, and fax.
These buttons do not work when the x1270 is installed on a Linux system since Windows is required. At this date the Lexmark site provides software for Win2K thru Win7 and no Linux or Mac. Information for a Linux install can be found searching online and I have done so. I don't know about Macs on this.
Apr 02, 2010 | Lexmark X1270 All-In-One InkJet Printer
Computer not accepting printer
Please install the Lexmark printer on Windows XP using the "Add Printer Wizard" by following the steps given below:
1. Go to "Start," "Control Panel" and "Printers and Faxes."
2. Click on "Add Printer" and then click "Next."
3. Select "Local Printer" and then click "Next."
4. Select the required Port (USB001 Virtual Printer Port if the printer has already been connected) and click "Next."
Note: If the printer has not been connected, select "File."
5. Click the "Have Disk" button.
6. When the "Install From Disk" screen appears, click "Browse."
7. From the "Locate File" screen, in the "Look In" option, select "Drivers."
8. Click "Open" and then click "OK" in the next screen.
9. When the name Lexmark printer is displayed, click "Next."
10. Leave the name as Lexmark printer and choose whether or not you want the printer to be the default.
11. Indicate whether or not you want to print a "Test Page."
Note: This is the "Windows Test Page." It won't be printed before the cartridges are selected.
12. Click on "Finish." The printer files will then start to copy from the CD.
13. Please follow the on-screen instructions to finish installing the printer.
your's tech expert
Jeeth
Mar 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
My lexmark x1270 will not print
install new cartridge...............install proper driver for your model from the website ........take a test page ......
Feb 03, 2009 | Lexmark Z640 InkJet Printer
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 1200 Series
unplug your usb cable,uninstall printer then reinstall
Nov 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 Not printing.
Did you put the right numbers of the cartridges?
Sep 30, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printer not printing
ok..disconnect from computer..try restarting with hard power down(unplug from wall)..
turn on again..try to do a test page from front panel
Aug 18, 2008 | Lexmark X1270 All-In-One InkJet Printer
LEXMARK X1270 NOT COMMUNICATIN WITH MY COMPUTER
i do not have its disk and I want to download it, so I need help in order to be able to install it without its disk
please send me email that how I can set up it.'
thank you for your nice cooperation at this matter.
yours turly
karim shah
k_shahrniya@yahoo.com
Jul 25, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
158 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
