We are assuming that you are talking about take off the harmonic
balancer, you need to know that probably allow 2 hours in case you run
into any issues. The only special
tool you're going to need is a crankshaft holding tool, usually parts
stores like autozone have them available for rent, which will hold the
crankshaft pulley so you can loosen the crankshaft bolt and remove the
pulley (it's not really a balancer on a Honda)
There's a special tool that holds the crank pulley while loosening the bolt. I use a 3/4 inch impact gun which has more torque when I can't loosen it with the 1/2 inch impact gun. Another option is to use a 1/2 inch breaker bar
with a pipe over the bar to act as a cheater, and if that doesn't work
you can try setting it against the frame or ground while tapping the
ignition. If doing so be sure to disable the coil so it won't start of
course.
You first need to lift the car off the ground like your changing the
tire(get it on a cherry picker if you can for easier access). Take the
tire off, loosen the tensioner on the alternator, and get the belt off.
Take a 11/16"ths shallow 1/2" socket and a 14" or larger steel pipe for
torque because this bolt is very very tight and can easily break your
tool. There are a few impact guns to take it off.
According
to my manual you can push a large screw driver in a hole near where the
speedo cable connects to the gear box to lock the flywheel. I found I
had to remove a small bolt to get the hole large enough to fit the screw
driver in. A small piece of casing broke and it became very easy to
lock the flywheel. The bolt came undone with a socket and a 30 in bar. I
don't think the missing casing is going to make any difference.
Fig. 10: On all engines except VTEC, the belt adjuster arm must be locked in place using one of the lower cover mounting bolts
Fig. 13: The balancer shaft must be held in position during timing belt installation
Good luck and hope this helps.
