Question about Whirlpool GD5SHAX Side by Side Refrigerator
GD 5SHAXKT02, SM0356525, Type 25SSA, 01/02
We turned the water supply off to the refrigerator while we were on vacation, When we returned we turned the water supply back on. The water comes out of the door as normal but the ice maker will not call for ice or will not make ice. I think that the water line is frozen. How can we thaw it? or does this sound like another problem.
Me tooooooooooooooooooooooooo help
Posted on Oct 14, 2008
Lg refrigerator can i turn water supply off but leave fridge freezer on when i go on holiday
How long of a vacation are you planning?
I would not mess with the fridge/freezer.
Leave the water supply on.
Jul 05, 2017 | LG Refrigerators
I have a KitchenAid side by side fridge, type 25SSA, water is leaking from bottom of ice maker down front of freezer and into ice bin, how do I stop leak?
Is the refrigerator and the ice maker level? Does it appear that the ice maker is over filling or slowly overflowing due to a leak in the Click here=> W10408179 Refrigerator Water Inlet Valve? Look in the rear of the ice maker where the water fill tube enters the ice maker do you see water freezing and running down to the ice bin from there? Let me know.
http://appliance911seabreeze.com/
Nov 14, 2015 | KitchenAid Refrigerators
We turned off our water for the entire house for a month long vacation and when we returned and turned the ater back on our refrigerator no longer dispenses water. When we press the lever we only hear a...
Hi sometimes when you turn water off to the water valve on the refrigerator the valve siezes up, you will probably need to change the water valve if it doesnt come loose. The run about $40-70.00
Sean
Mar 29, 2011 | Maytag Refrigerators
My refrigerator Kenmore coldspot type 25SSA it work but no cold in both side.
Most likely the compressor is out of refrigerant gas. This can happen a little at a time or get a big leak and happen all at once. This is a job for a licensed refrigeration contractor.
Feb 24, 2011 | Kenmore 57029 Side by Side Refrigerator
Refrigerator not cooling but freezer cooling. KENMORE 25SSA
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | Refrigerators
Type 25ssa , sounds like the fan motor , where do i get a replacement fan
You should be able to get one at any appliance parts supply house. They carry many in stock, and your motor will likely be there, as Whirlpool is a commonly carried replaement part.
Best regards, --W/D--
Aug 16, 2009 | Whirlpool Refrigerators
Icemaker stuck in 'vacation mode'
Feel inside the ice slots are there any old cubes that have evaporated in time? Take the ice maker out and clean it up and place it back inside to see if it will fill with fresh water. Take a hair dryer and melt the old ice inside the slots and see if it will try to fill. I will wait for a response from you.
KSCS25INWH00 Kitchenaid Parts
APPLIANCE 911
KitchenAid Refrigerator Ice Maker Assembly 2198597
May 06, 2009 | KitchenAid Superba Architect KSCS25IN Side...
I have a GE Profile refrigerator the does not produce ice cubes
the fill tube that runs water into icemaker has most likely frozen up use a hair dryer and heat the tube up until the ice melts out then it should start up agian. you may have to remove the icemaker to gain full access to the fill tube. good luck peyton
Jan 24, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool GD5SHAX Side by Side Refrigerator Logo
175 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
