Question about Siemens SpeedStream 4200 (13A4200001) Bridge
Siemens 4200 can i use 2 computers?
You cant connect 2 computers without any additional equipment. U can go for router to connect more computers.
Take care
Posted on Jul 24, 2008
I have a siemens 4200 adsl modem i had a net gear modem before and that was not working with wireless internet and now this modem wont let me connect wireless either only with the ethernet cabel. help!
Hello Mate,
the siemens speedstream 4200 is a DSL modem/Router which doesn't have wireless connection. So even tough if you have a computer equiped with a wireless adapter, you will not be able to connect wirelessly because the siemens 4200 doesn't act as wireless access point.
You may need next time to check first if the modem/router to buy support wireless (wifi g or n) and make sure that it's not only a modem, it should be also a router.
i attached here some references for you from the top brands:
1. Linksys DSL modem/Router with wireless N: http://www.linksysbycisco.com/MEA/en/products/WAG120N
2. Linksys DSL modem/Router with Wireless G: http://www.linksysbycisco.com/ANZ/en/products/WAG54G
You can find other brands as Dlink, Netgear ...
Best Regards,
Oct 29, 2009 | Computers & Internet
I have a siemens speedstream 4200 modem. It gets very hot to the touch, is it good to turn the modem switch off sometimes when you have your computer shut down?
Sometimes it's normal for some modems to be very hot. Make sure it's no in a very enclose space. And yes it's ok tp turn the modem switch off sometimes if you have to shutdown the computer. Just be sure to turn on the modem first then the computer in that sequence when you need to use them again.
May 08, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Siemens 4200 2 computers
Yes and No! The 4200 gives you the option to connect via USB or Ethernet. You can only use one or the other to connect. You have two options. The first DOES involve another "gadget". The second does not!
Solution #1
I realize you're not looking to use additional equipment, but a network hub, switch or router will give you what you need. You can pick up a very inexpensive router for under $50 or even better a wireless router for a few bucks more.
I recommend a Linksys Wireless Router (Model - WRT54G) as it is very user friendly and comes ready to use. Just connect the port labeled "Ethernet" to the "WAN" port of the Linksys Wireless Router. Then connect both of your computers to any of the four "LAN" ports.
Solution #2
You can connect the first computer directly to the 4200 via USB and connect the second computer directly to the first computers ethernet port using a Network Crossover cable. Without a router of hub between the two computers, a crossover cable is required to allow them to talk to each other.
Once you have them connected to each other, on the first computer open the network connection properties for your internet connection (will be the one setup during the install of the USB modem) and click "Share This Computers Internet Connection".
Now the first option is surely the most reliable and keeps the traffic separate.
Hope this help!
Jul 20, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Need help with siemes speedsteam 4200 port issues
Please goto the below link and select your game and see the document for portmapping.
http://portforward.com/english/routers/port_forwarding/Siemens/4200/4200index.htm
With Regards,
TPV
Jan 05, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Setup Siemens 4200
u need to get an installncd from them or at least the manual install setting so that you can manually configure your computer.
Nov 23, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens SpeedStream 4200 (13A4200001) Bridge Logo
202 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
