Question about Toshiba Satellite P15-S479 Notebook
Wifi troubles my computer says wifi is fine, however it does not detect any wifi signals, other computer in same room are getting signal fine.
  • Ed Deguzman
    Ed Deguzman May 11, 2010
    Do you have Vista or XP ?
  • 43 Answers
Hello. If you are sure that your`s computer wi-fi is fine, then it seems it is a hardware problem.
Posted on Jul 29, 2009
My smart TV has home wifi but is intermittent. Router is in the next room. Tv can find Belkin but then my house wifi is unticked. Does it not work for a smart TV? Why does it switch off my wifi?
Your set may have a defective wi fi detection circuit that is causing all the grief. I had to return a laptop for this reason.
Maybe the signal is weak - try raising the router as high as possible off the floor and also try putting a deflector behind the router to direct the signals in the direction of tv set to maximize strength.
Sep 11, 2017 | Belkin Computers & Internet
Why is the TV not connecting to wifi?
BECAUSE WIFI IS FOR COMPUTER SIGNAL FOR INTERNET ONLY TV IS FOR MONITOR VIDEO SIGNAL AUDIO SIGNAL FROM ANTENNA CABLE SATELLITE BOX THROUGH TUNER TV TUNER CAN NOT RECIEVE WIFI
Oct 18, 2015 | Televison & Video
Sony ericsson w890 wifi not working
Check weather any other device can detect wifi signal of your modem router. If it cannot detect the signal then it may be the complaint of your modem roter wifi.
If the other device can detect wifi of your modem router then back up the data of your phone and reset it. It will work fine.
Thank you
Jun 04, 2012 | Sony Ericsson W890i Cellular Phone
MY LAPTOP DOES NOT CATCH ANY WIFI SIGNALS
methinks that you need to check these two items first
a. look for a physical switch along the sides of laptop(could be sure if the model number were here) and turn it on
b. open start/control panel and look for wireless icon click on that and ensure it's active
if that does not work then make sure you have one installed
start/control panel/system icon
opens panel go to device manager(should be upper left first option on list)
look for network adapters
see if wireless is listed
if it has a yellow ? mark then you need to right click to uninstall
go to top of that panel and scan for hardware changes
may need to restart computer after this segment is complete
May 25, 2012 | Computers & Internet
Cant keep ipad2 connectd to netgear wnr1000 vs
Sounds like the Ipad is getting out of "readable" range of the WiFi signal. You might log into the router and change the channel to channel 1. If that does not work, try another channel. If no channels work, you will probably need a Wifi extender to get the signal upstairs and readable for the Ipad.
Jan 26, 2012 | NetGear WNR1000 Router
My Dir 615 is working very fine but up in one room the signal is very weak. How can I get it stronger? Thank you,
Hi - Wifi devices are very low power. Under optimal conditions, they can transmit up to 100 yards. Optimal conditions are basically an unobstructed "line of sight".
The number of and the more substantial the obstruction, they greater the impact is on the signal. An example is the devices (computer and the router) are separated by 40 feet and a single Sheet Rock or gypsum board and wooden wall; like you might find when a computer is being used in the back yard and the router is inside the house in a room next to the back yard. The signal should be relatively strong over this distance and this minimal obstruction material. Compare this to the same distance of 40 feet, but the wall is now brick or concrete, and there is a second wall like the first example - but it has a coating of aluminum; and there is a wooden floor; all between the computer and the router. That is an example is what you might find if the router were in a second floor room at a neighbor's house that has aluminum siding and the computer is in a basement of your house. The signal may be so degraded by aluminum, wood, concrete, soil and gypsum obstructions that the speed is very slow or isn't usable at all.
Now you've got an idea as to how the materials of the obstructions can wreak havoc on a wifi signal. There are also issues of interference. Most wifi "b", "g" and "n" signals operate on 2.4Ghz and and 5Ghz frequencies. These same frequencies are employed by other low power / unlicensed consumer devices - most notable are cordless telephones (not cell phones), microwave ovens, Bluetooth devices and baby monitors. If enough of these devices are in the area or between the router and computer, they can disrupt the signal significantly as well.
So, if the space between the computer and router are close, but you're still having trouble - look for these popular consumer devices. Unplug them / remove batteries and see if the signal improves. Move the router to a centrally located point in the area that it is to be served. Pay attention to the types of materials that the signal must pass through - air, paper, and wood aren't too bad. Brick, mortar, soil & metal can substantially reduce signals very quickly. It is better to have the router above the area to be served rather than below it.
Lastly, check the channel that the router is being operated on. The band of frequencies for "b" and "g" wifi consists of 11 channels (1 through 11) in the U.S. The best frequency to use is channel 5 (ch 5) or channel 6 (ch 6). This is because it is in the "middle" of the band (like the way 98 is middle of the 88 - 108 FM broadcast band). Other signals *may* be on the frequencies above ch 11 and below ch 1. Being on 5 or 6 keeps as much space between YOUR wifi signals and those that aren't wifi types. Ch 5 or Ch 6 may already be in use by a neighbor. If that is the case, you both will be on the same channel and the signal will be significantly reduced. Try to get as far away from his or her signal as possible - this may mean ch 3 or ch 9 - or maybe even ch 1 or ch 11 under the right conditions.
I hope this helps and good luck! Please rate my reply. Thank you.
Oct 03, 2011 | D-Link DIR-615 Wireless Router
My laptop no. is compaq CQ 60 104TU.I am facing problem with connecting to internet via wi-fi..yet i fill password correctly. What can i do?
Computer networking is attained either as wired cables or wireless observations. Recent innovation devices capture networking with signals also kwon as wifi. Observe the compartibilitie of the computer to ascertain that were wireless compartible. In which instance, wifi computers detect available signals from alernate devices either computers or peripheral devices. Prior to requesting wireless or wifi from computer devices, an area on the device allows to set functionality. Once the computers wireless features are establshied should detect available signals present on alternate devices. Each devices from which signal communcations are requested require adjsutments to capture as request resource exchage. For example, two computers that both are wireless compartible should set wireless features to capture available signals. In the situation, each computer detects the alternate as an icon representation displayed that would request details to complete communcations. For example, the wireless network structure where one computer creates password protect to least display on the alternate requires requesting password unblocked. Determining the entity that sets the password either as computer owner operator may allow password unblock or share the passcode to be type keyed to the alternate computer whenever requested.
Feb 20, 2011 | Compaq Computers & Internet
M675 Notebook Wireless Problem
yeppers..those are simply receivers, and sometimes, after a period of time, and vibration, and shock, they just lose some of their ability to tune into a signal. I've seen it in net cafes and inside wireless nodes too.
got backup for your Gateway?
Feb 12, 2008 | Gateway M675 Notebook
How do I receive the signal with another computer?
Hi, I have given ya a link that will explain all... http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx www.microsoft.com/athome/moredone/wirelesssetup.mspx Basically you give the Wifi Router an SSID (Unique name, say, AlrenaWiFi... whatever ya like though) Then on the "Remote" if it isn't already, you activate, "Enable" the WiFi adapter... and when enabled, the adapter then "Detects" the (any) wifi signals, you are asked if you want to "Connect" choose YOUR wifi SSID (Name) click connect and you will Be done. Now, thats for an unsecured network, for a "Secure" network, one simply has to assign a "WEP Key" to each "end" as an extra step. This is all explained in the tutorials.
Aug 28, 2007 | Linksys Wireless-G Broadband Router
Toshiba Satellite P15-S479 Notebook Logo
99 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
