Yes and No! The 4200 gives you the option to connect via USB or Ethernet. You can only use one or the other to connect. You have two options. The first DOES involve another "gadget". The second does not!
Solution #1
I realize you're not looking to use additional equipment, but a network hub, switch or router will give you what you need. You can pick up a very inexpensive router for under $50 or even better a wireless router for a few bucks more.
I recommend a Linksys Wireless Router (Model - WRT54G) as it is very user friendly and comes ready to use. Just connect the port labeled "Ethernet" to the "WAN" port of the Linksys Wireless Router. Then connect both of your computers to any of the four "LAN" ports.
Solution #2
You can connect the first computer directly to the 4200 via USB and connect the second computer directly to the first computers ethernet port using a Network Crossover cable. Without a router of hub between the two computers, a crossover cable is required to allow them to talk to each other.
Once you have them connected to each other, on the first computer open the network connection properties for your internet connection (will be the one setup during the install of the USB modem) and click "Share This Computers Internet Connection".
Now the first option is surely the most reliable and keeps the traffic separate.
NO, the DSL port should be plug into the phone line. However if you can purchase a 4 port 10/100 switch/hub, plug the switch into the unit using the ethernet port and then into the computers using the extra ports in the switch/hub it will work.
OAM SegmentTest ATM OAM segment pingFAIL DNSPing the primary Domain Name Server FAIL PPPoETest PPPoE...
(More)
OAM SegmentTest ATM OAM segment pingFAIL DNSPing the primary Domain Name Server FAIL PPPoETest PPPoE Server connectionN/A PPPoE SessionTest PPPoE sessionN/A How can i do the fail to a pass? & the N/A to a pass? The name of my router is: Siemens SpeedStream 4200 thanks
I have a PC with IP Address 192.168.2.10 Subnet Mask 255.255.255.0 Default Gateway 92.168.2.1...
(More)
I have a PC with IP Address 192.168.2.10 Subnet Mask 255.255.255.0 Default Gateway 92.168.2.1 SpeedStream 5242-Series DSL MODEM. It appears to have IP Adress 70.54.9.146 Subnet Mask 255.255.255.255 DNS Server Address 67.69.235.1 Modem IP Adress 192.168.2.1 I also have a D-Link Wireless Router WBR-1310 I thought the D-Link router would be acting as my DHCP server with a default address of 192.168.0.1, giving my PC an IP adress of 192.168.0.2 or some such. However, it looks as though the Speed Stream modem is acting as the DHCP Server? When I ping 192.168.0.1 I get no response. I can't see the D-Link router at its default IP address. If I cannot access it I cannot get into the configuration utility to apply security measures (I want to enable just the mac addresses of our PCs so no one else can get onto the network.) Do you have any ideas? thank you, Bruce
