Question about Whirlpool GD5SHAX Side by Side Refrigerator
Whirlpool Gold GD5SHAXKT02 SM0356525,type 25SSA
We cut off the water supply to the refrigerator while we were on vacation. We turned the water supply back on when we returned, water comes out of the door but the ice maker will not make ice or call for the water. Is the line possibly frozen to the ice maker and if so how do we thaw?
  • nikog Aug 02, 2008
    Water comes from the door but no ice is produced nor is there any water in the ice tray. Line doesn't appear to be frozen.
    Haven't really had time to trouble shoot yet.
SOURCE: GD 5SHAXKT02, SM0356525, Type 25SSA, 01/02
me tooooooooooooooooooooooooo help
Posted on Oct 14, 2008
Hi. I have a side by side refrigerator made by whirlpool. It's ED5NHEXNBOO, Type 25SSA. Do you have any info on that?
what kind of info? if you're looking for an owners manual you can go to Whirlpool.com and you can download most manuals.
May 22, 2010 | Refrigerators
Hi. I have a Whirlpool sise by side gold
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Type 25ssa , sounds like the fan motor , where do i get a replacement fan
You should be able to get one at any appliance parts supply house. They carry many in stock, and your motor will likely be there, as Whirlpool is a commonly carried replaement part.
Best regards, --W/D--
Aug 16, 2009 | Whirlpool Refrigerators
Water dispensing too slow.
The water filter might need changing. Make sure the water supply is completely on and has good pressure.
Oct 21, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer frozen fridge not
you will need a multimeter. check continuity thro defrost heater and thermal fuse in series with it. if it is a electro-mechanical timer to control defrost, then this is the most common fault. if controlled electronically and heater and thermal fuse are ok, then points to a module fault.
also if wiring is plug and socket, check these are ok
Aug 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Refrigerator
When this area gets very hot, it's usually because of inadequate air flow across the condenser coils under the refrigerator. Check to see if the condenser fan has stopped blowing underneath. Remove any obstructions or replace the fan motor if it has stopped. Also clean any accumulation of dust from the coils. The refrigerant line runs down the divider at the front of the unit to warm it slightly and prevent condensation and/or frost there, but it should not be noticeably hot.
Jul 28, 2008 | Whirlpool GD5SHAX Side by Side...
Whirlpool GD5SHAX Side by Side Refrigerator Logo
408 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
