Question about Mitsubishi WS-55807 TV
Frustrated with tv repairman
I have a Mitsubishi HD WS55807, Had the screen turn blue and red convergence would go off and then straighten back up,but was able to see the program, until the next day when it would not power up at all. Called a local repair service & they took it for a week, they replaced horizonal & vertical convergence hold & power pack and fuses. He said glycol had leaked onto the big chip (Panasonic MN102H57KMA 020U4M85)on the one board. He repaired the leak and cleaned around the chip, then put some kind of sealant on the chip. Said in high humidity the glycol creates a white residue and we could have more problems.
About two weeks after getting it back the screen turned pink. Called the repair man and he came in & cleaned the chip,(Panasonic MN102H57KMA 020U4M85)with amonia. Told us it may need to to go back to factory to be repaired(they don't make replacement boards for this model).
The third time he came back, a week after the second time because the screen went pink again, he cleaned this chip again. I cleaned this chip two times now with amonia, because he showed me how to clean it and said to use amonia.
When the screen goes pink, it doesn't stay pink, it goes back and forth from pink to a clear picture.Is this the problem?
  • 927 Answers
Good day, rickbowers;
This may be your problem, this model is known for this concern. But let me ask you; is there more fluid on the board? If so put some type of "sheild" over mentioned area. Some shops use a thick cardboard or others use a heavy plastic, install over entire area.
Try this first.
Let me know, good luck, big IRISH.
Posted on Jul 30, 2008
Mitsubishi tv ws 65315 red screen
if the reds and blues look 3d etc it is a convergence problem. see attached photos of a typical convergence problem.
Apr 28, 2012 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi big screen rear projection tv the blue
The tv 100% have convergence problems,it dead.If any colors lines don't matches or stay in the - + convergence grid.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv conververgence board must have these parts changes to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Mitsubishi Televison & Video
Convergence is way off, Rt & Lf side of screen has red & blue around objects
Convergence IC's inside of your TV have to be replaced. Also some low value resistors around IC's could be burned as well.
Then convergence have to be realigned. This job require above-average soldering skills and cost around $300 if you hire TV repairman to do that.
Regards.
Russ.
Apr 04, 2010 | Mitsubishi WS-73907 TV
The colors red blue shake back and forth on the ws55807 mitsubish
maybe you need to goto menu and auto converge colours..
try degauss feature if avail..
Is it a projection tv if so you may need a flyback anode block for R,B guns.
Dec 16, 2009 | Mitsubishi WS-55807 TV
Blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
Mar 15, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Concaved distorted picture in 1080 Mitsubishi 65" TV.
This is a convergence rpoblem that is either bad connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside TVs where there are potentially dangerous high voltages, let me know and I'll provide additional details and instructions for fixing this yourself.
Dan
Dec 11, 2008 | Mitsubishi WS-55807 TV
Red is out of alignment
when i go to convergence and align the white cross with the blue its ok ,but when i try the red it doesnt line up and if l get it close enough it get misaligned only with the red ,green and blue fine
Nov 15, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55807 TV Logo
133 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
