Question about Motorola Mobility RAZR V3
Screen My external display is blank, blue.
  • rhgoog Oct 01, 2008
    Same problem. BOO!
    Brigadier General:
  • 7,752 Answers
Have the lcd replaced on the phone
Posted on Jul 21, 2008
I have a dell studio 1558 laptop, suddenly while using the laptop the screen for blank so i did a hard shutdown. After that i tried starting my laptop, but there was only blank screen. I attached my...
Seems like a two fold issue here. The blank screen is possibly a faulty laptop display or inverter but the blue screen is caused by powering off the laptop whilst it was doing something and now has damaged files. With your external monitor connected power up and try to reach Safe Mode and let windows find the issue and attempt a repair or press F8 and select repair OS. When you have repaired the OS, shine a bright light at the laptop screen and see if the inverter is not running or a dead screen.
Oct 28, 2014 | Computers & Internet
Have dell inspirion1525. Screen is black. By holding down fn key and start key i get flashing lock with 9 and blue lock wih an A and blue lock with a down arrow. What do these mean?
Well the Flashing "lock with 9" is Num Lock, the "blue lock with an A" is Caps Lock, and the "blue lock with a down arrow" is Scroll Lock. Hope that answers that question.
Now for the screen being blank usually means there is an issue with either your LCD display or an issue with the laptops video card. Plug in an external monitor and boot up the laptop if you still get a blank screen then there is an issue with the laptop's video card. If you can see your screen on the external monitor then there is an issue with the connection of the LCD displayon your laptop. You can try ifxing it your sleve by opening up the laptop and making sure the connection is firm or you can take it somewhere to get it fixed.
Please rate if this helps
Mar 15, 2011 | Dell Vostro 1500 Notebook
BLANK SCREEN
Your Back light has most likely gone out.. There is a possibility that your resolution may be to high or that you have it set to output on an external display... If its your res. you should be able to hit F8 at startup to enter safe mode... If it is the external display you need to hit FN + the key that has a little blue or yellow monitor (its a different key on each laptop)
Dec 11, 2008 | Acer Aspire 5050-3242 Notebook
Blank Screen
If you can hear your windows loading but no display, try plug-in an external Monitory on your Laptop. If you can see the display on the screen with this monitor then maybe your LCD or Inverter is broken, or try turning on/off the switch for External Monitor and LCD Display on your keyboard. Usually by holding the "FN" key on your keyboard and look for the LCD/VGA icon on your keys then press it.
-mrsolution
Jun 11, 2008 | Toshiba Satellite A135-S4527 Notebook
I own a evo n510c
If you are hooked up the the external monitor and/or TV and can see the desktop, you can probably reselect the internal display via software from Display Properties.
In most cases you can change from the external display to the internal and vice versa by holding down the blue Fn key, and hitting the proper number on the keyboard. The correct key has a blue icon meant to resemble a monitor on it.
This is if the repair/replacment of the internal screen was done correctly and the screen is actually working. If the screen is not actually working, though, this will not help you.
Jan 28, 2008 | Compaq Evo N610C Notebook
Front display is blank
this is a tech fault which will require a tech to deeal with it hands on
Dec 09, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
External Display
This is a hardware issue. The flex cable connecting the displays is loose or broken. If the phone is new, you can get this repaired under warranty.
Dec 01, 2007 | Motorola Mobility RAZR V3
External screen blank, blue backlite
have the LCD screen replaced take it to a mobile service center and have it replaced there.
Sep 04, 2007 | Motorola Mobility RAZR V3
Motorola RAZR
your external screen needs replacing...you would have to take it to an authorised repair person to replace it because it's very tricky to change. Sam !
Sep 01, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
115 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
