Dell Latitude XT2  Tablet PC Logo
A
Anonymous Posted on Feb 02, 2011
My Dell XT2 tablet pen doesn't work. - Dell Latitude XT2 Tablet PC
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Feb 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
5062
Points
24
Did you install the correct N-Trig drivers for your pen ? You can find them at http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs and by entering your TAG number which is located underneath your tablet pc.
1helpful
My Hdd is locked on my Dell XT2 I have the password but I cant find where to put in the Password
Restart the computer and tap F2 key during POST to enter System Setup (BIOS). This should prompt for the Hard Drive (HDD) or BIOS password. Knowledge Base
This should help.
While the computer is powering up keep tapping f2.
Turn it off. Press the power button again and keep hitting f2.
My tablet won't charge.why???please help!!
Is your battery removable? Try removing the battery and then plugging in the tablet. If the tablet runs on only the AC power, then your battery is shot.
1helpful
Master hdd password
I believe the only way to remove it is to contact Dell with your service tag number.
1helpful
Dell Latitude XT2 sound doesnt work 1/2 of the time. Windows 7.
Download and install the drivers from manufacturer website. If you are unable to recognize the device specific drivers then i would suggest to use the driver scanning tool, it will search for the drivers online and will show a list of of device specific updated drivers.
You can download the driver scanner tool here:
www.DriverScanner2013.net
How can you get the touch screen or pen work on the dell latitude xt2? I can't figure out how to get the buttons to work or the screen to rotate.
What OS are you using ? Windows Vista or Windows 7 ?
In order to get the buttons and touchscreen working, you need to install the proper drivers.
Go to http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_XT2&os=WLH&osl=en&catid=&impid=
Select your operating system
and download the following drivers and install them in the following order :
  1. System Utilities : - > Dell Utility : System Software
  2. ControlPoint -> Dell - Application : ControlPoint System Manager
  3. Input device drivers - > Ntrig Application
Restart your computer. Run Windows Update Restart your computer Everything should work.
Pen and touchscreen not responding on my Dell Latitude XT2 Tablet PC
Hmmm does the penn have a battery then? I guess something is wrong with the wiring as not just the pen does not work but touching all all not. Stuff should just simply work and not require loads of troubleshooting.
1helpful
2answers
How do I enable presentation mode on an XT2 tablet? I am in a meeting connecting a Dell Tablet XT2 to a Panasonic projector via vga cable and trying to use Fn8 to display the laptop screen. The setting...
You could be able to enable presentation mode by pressing the "settings" button on the bootom of your display, next to the power button and the "ctrl" and the rotate button. After you press that, your dell control point manager should pop up and then go to the tablet tab on the left and open it. after that, go to the display tab and you should see an option that allows you to turn your presentation mode on.
3helpful
4answers
Dell Latitude XT2 fails to start up.
I know this is an old post, but the LED code for CAPS lock on, F4 flashing, F5 on means memory issue. I had this issue, reseated the memory, and the issue was resolved.
Top Dell Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Josh Lake
Are you a Dell Tablet and eReader Expert? Answer questions, earn points and help others
