Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL 40X2000 HDMI both cutting out
We have our PS3 and DVD player connected to the two HDMI connections, both are loosing the signal, screen goes black, sound is out sourced elsewhere so we know it is the TV's HDMI as we still get sound, Sony say they have never had this happen, any ideas?
  • gman May 24, 2013
    Sony Bravia KDL 46v5100 with e328 patch. HDMI ports keep resetting. Sony knows but is not able to fix.
    New Friend:
Http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C1003157&fes=true
Posted on Dec 20, 2012
  • 320 Answers
Sounds like a handshake problem with the HDMI outputs on the devices. I have never seen BOTH HDMI inputs have the problem. It could be a problem in the TV where the HDMI signal is processed or the HDMI jacks may have been stressed and this is why you have an intermittent problem. By stressed I mean that the jacks have been bent by inserting the cables wrong or pulling up or down on the cables when they were plugged into the unit.
Posted on Oct 19, 2008
My ps3 console signal isn't working but the sound works but there is no signal! not even a hdmi cable works help!
Try these tips to fix the so-called "black screen of death".
Tip 1: The main reason of HDMI black screen problem due to HDMI cable may be damaged and not properly connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:
1) Restart your PlayStation 3.
2) Look for loose cables.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damaged, borrow a friends cable and try it. If your friends cable works fine, and the black screen error disappears. Then you can buy a brand new HDMI cable for a replacement.
Tip 2: Only try as last resort. There is a possibility you'll lose all data on your PS3's hard drive. If tip 1 didn't work, you will need to go a step deeper and reset your console. Most PS3 gamers are not aware that Sony actually included a black screen of death troubleshooting method and other HDMI problems in the PS3 manual, you can find it under the troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data on the hard drive.
You will need to perform the following steps:
1. Place your PS3 in stand-by mode.
2. Hold down the touch power button until a series of beeps are heard.
3. Listen for one long beep, followed by two shorter beeps.
4. Release the power button.
5. Follow the instructions on screen.
If it works you should be good to go.
May 20, 2012 | Sony Playstation 3 (PS3) Console
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Black Screen - No Signal when connect Bluray to TV with HDMI
I just had the same issue and I believe it was because the sound bar was turned off. The solution was turning on all of my connected equipment such as my sound bar, cable box, tv, blu-ray player, and internet router. It stopped "disconnecting" after only 30 secs of being turned on. I think it was because my husband connected it to all those things in some way so the settings are set to work with those pieces of equipment. With one powered off, in my case the sound bar, the signal can't run full circle and reads as if cut off. Please excuse my nontechnical terminology.
Dec 28, 2011 | Philips BDP3000 Blu-Ray Player
My HDMI will not work when trying to connect to PS3. It has worked before, but not consistently. Is there a way to reset the TV or is this caused by something else? The screen just stays black with the...
Does other HDMI source work? Cable Box? DVD?
If none of these work, you probably have damaged the HDMI chip. The contacts on the connecter are very tiny and close by. If you twist it while the set is on, signals can short and damage the interface.
It is not worth the trouble replacing it.
Sep 21, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Multiple connections to Yamaha V463
Each HDMI port has its own source, such as DVD, Radio, etc. When you switch sources on the receiver, it sends the appropriate signal to the television. If I'm not mistaken, the 463 is only a pass through unit not a converting one so it you hooked up your DVD player through the S Video or Component it may not send the signal to your television through the HDMI, since it takes a converter to change the source from Analog to Digital. May be wrong on the unit though.
Component is better than S-Video. Also, use a fiber optic cable for sound from your DVD player if it has one. This setup will be the closest to HDMI, some argue better.
Feb 17, 2009 | Yamaha RX-V463 Receiver
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
No signal when connected via hdmi to dvi on tv
ya nothing shows up is all black no sound nothing
Oct 27, 2007 | Sony Playstation 3 (PS3) Console
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
818 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
