Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca p60752eb Hello, I seen your response to someone else about a power supply. My tv while I was watching it made a popping sound, shut off, and now when I push the power button it makes a buzzing sound. No picture or sound. Would this be worth fixing.
  • traroman Jul 20, 2008
  • blabbermo458
    blabbermo458 Apr 22, 2012
    i had the same problem. was it the bulb or something of that sort?
    i was playing xbox all the sudden a loud pop noise no picture and some sort of static noise
  • RCA Master
  • 8,617 Answers
Sounds like the flyback, can you look on the rear tag and let me know which chassis you have and verify your model number and I will post which flyback you need as well as where to get a replacement with free tech support to help you install it.
Posted on Jul 21, 2008
I have an RCA P60752EB Projection TV. There seems to be no power going to it now after transporr. It worked fine when I used it at home but when I moved it to a friend's house, it is dead. There is no...
hello am rico, first look for cold solder in your power supply, you need to open the back of your tv to do that. if you need more help, feel free to call me at anytime. 602-810-7149.
Jan 07, 2011 | RCA P52926 52" Rear Projection Television
My RCA p60752eb does not come on its makes a crackling sound, but does nothing else
u may have a bad capacitor on power supply 2200uf 25v, just look at the power supply this cap is big u can not miss it
Aug 25, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture problem with a rca home theater model p60752eb
I have a problem with the colors on my RCA Home Theater model #P60752EB. I believe it to be faulty tubes or something cause my green and my red color is messed up to the point it will not come in at all.what should i do to resolve this problem without replacing the tv
Feb 15, 2009 | RCA P52926 52" Rear Projection Television
Tv picture goes off but still have sound.
Resolder all poor connections on power supply board and this should fix your problem.
Feb 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA p60752eb no picture porblem
most likely its a vertical deflection issue, try soldering the vertical otput IC as that may just need to be resolderd, if that doesnt help try replacing the Vertical output.
Sep 16, 2008 | RCA P60828 TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
Rca projection tv has sound,no picture or OSD
The 169 is an old chasis but a good one. Many chronc problems can cause these symtons. No high voltage because of bad flyback, or HV spitter defec is the most likely, but there are chonic caps that fail in the power supply as well. This problem will most likely need the assistance of a qualified service professional.
Feb 10, 2008 | Televison & Video
RCA rear veiw projection tv
do you see any tiny lites you see on the end of the tubes or crts are the filiments?
Feb 04, 2008 | Televison & Video
My rca model P60752EB does not turn on.
this particular rca also know as a itc222 chasis has a safety shutdown cuircit.. if it detect any problem. high voltage. over current over voltage ..one of 20 problems. it will shut down. if the unit tries to come on that idicates its more than just a fuse. first question u ask is after the set been unplug for 30 minites then plug back up does the set come on or try to come on does the led light flash on the front. does it try to come on 3 times then shut down. there is special diagnostic equipment techs used to read errors recorded in the processor.
Feb 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
148 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
