Question about KitchenAid KCM511OB 10-Cup Coffee Maker
Re: KitchenAid Coffee Pot
Keeps giving me "Err4" and will not work. Any solutions?
  • 3 more comments
  • Anonymous Jul 22, 2008
    Err 4
  • rgray625 Aug 11, 2008
    kitchenaid kcm5110 worked fine until i cleaned it with vinegar. now i get err2. if i hold the on off button in, i get err4. either way, when i go to make coffee, it doesn't work.
  • Anonymous Oct 24, 2008
    same problem, My mom cleaned mine with CLR in a fit of niceness now the flipping thing is broken
  • Anonymous Jan 04, 2009
    any advise? is it toast
  • marehughes Jan 18, 2009
    My kitchen aid coffee pot has a red light blinking under the "cleaning needed"title. I don't have my manual. What cleaning method is recommended?
I had a similar problem with Err 1, Err2, and Err 4. To resolve Err 1, if you have room, remove the coffee filter and coffee, pour more "warm" not hot water into reservoir. If you have 4 cups cold water add 5 cups warm. Then start coffee maker and let it run thru. Then drain coffee pot and start over to make coffee with tepid water. Err 1 indicates the coffee maker temp sensor is too cold from room temp or water temp.
Err 2 is a result of cleaning. First question "Did you remove the charcoal filter?" The charcoal filter can be removed form the filter stick by prying two tabs away gently and removing the filter for removal. The filters can be purchased @ www.Kitchenaid.com
One pot run thru with descaler can loosen scale and make sensor go "blind". Just run a full pot of clean plain water thru one maybe two times. A pot solution should be a solution of 1/4 pot WHITE vinegar, 3/4 pot clean cool water. Run this thru once, then two clean pots of fresh water as if you brewed a pot of coffee. NEVER USE CLR WITHOUT RUNNING NO LESS THAN THREE CLEAN WATER POTS THRU MAKER!!!! This is so you can continue to enjoy drinking coffee, nothing like a cup cleaning you out!
Err 4 is simple, you have a stuck button. Unplug maker and gently press each button making sure they aren't stuck in.
Posted on Feb 05, 2009
Error 1
Posted on Nov 16, 2008
The button jammed solution is from the manual and hasn't worked for me. The problem for me was that moisture got onto the circuit board. I had to disassemble the coffee maker. Do this at your own risk. You'll need a phillips screwdriver.
There are four screws on the bottom of the machine that allows the bottom plastic to be removed. By shifting the exposed metal plate downward, you should be able to pull the faceplate that holds the circuit board that holds the LED lights and buttons. Carefully disconnect the two cables attached to the circuit board, one is bigger than the other.
At this point, there whould two plastic anchors you can push away from the edge of the board to release the circuit board. I tried a hair dryer to completely dry the board but this didn't work. I warmed the oven to 200 degrees for about 15 minutes and then turned the heat off. I placed the circuit board on a thick cookie sheet into the oven and left it inside the oven for an hour.
Inspect the circuit board to make sure it's completely dry. Then return the circuit board in it's plastic housing and reconnected the two cables to their mounts. Reassemble the plastic housing to the rest of the coffee maker. Replace the bottom plastic cover and replace the screws.
-rr
Posted on Jan 05, 2009
A button is jammed. Unplug the
Coffee Maker, press each button
several times, then plug the Coffee
Maker back in. (If the Coffee Maker
has been stored or used in a cool
environment, warm the unit to
normal room temperature before
doing this.) If “Err4” appears again
on the display, repeat this procedure
Posted on Dec 18, 2008
  • sam-coffee Dec 18, 2008
    or the water went in side the bored.....so try to open the front (don't breake it)and dry it
I am getting err4 and will not work
Help
Posted on Nov 23, 2008
My kitchenaid coffee maker gives us an "error 2" and will not brew. help!
This problem occurs between 6 months and 1 year of these coffee pots. I have contacted customer service each time this occurs and have received a new coffee pot. Unfortunately, I am calling them again and again because the new coffee pots do not even last their warranty time and the ERR2 light again comes on and ruins my morning. I would not recommend this coffee pot. It is expensive and life time is not long at all. Customer service has been great but how many times do you have to return a coffee pot for Kitchenaid to get the hint that it needs to be fixed. Most consumers will get angry, throw it away and never buy the same one again. So, wake up Kitchenaid and smell the COFFEE!!!!!!!!!!!!!!!!!!!!!!!!! Fix this coffeepot. I am not the only one who has had this problem. Customer service @ 1-800-541-6390 Hope this helps. When they send you a new one they send you free shipping back for the old one and you use the box the new one came in.
Dec 04, 2010 | KitchenAid KCM511 Coffee Maker
Kitchenaid coffee pot won't brew coffee reads err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Mar 13, 2009 | KitchenAid KCM511 Coffee Maker
Err4 message
On a Kitchenaid coffee maker, ERR 4 indicates a stuck button. Please double check to make sure none of your buttons are sticking in place and "freezing" the coffee maker. If you can not find any obvious problems, I would recommend calling Kitchenaid Customer Service to see what options may be available to you.
Their toll-free phone number is 1-800-541-6390.
Feb 06, 2009 | KitchenAid KCM511 Coffee Maker
Err4
ERR 4 in a Kitchenaid coffee maker indicates a button is stuck in place. Please be sure to check all of your buttons and see if any are stuck depressed into the machine.
If this is not the case, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Dec 31, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
Coffee pot reads err4
We are going to buy a new coffee pot a different brand. We took the 1st one back and now this one
isn't working with an err4 which no one knows what it is but everybody has it!! You want to charge a fee to fix it why??. We paid $60 for that coffee pot and expected it to work longer than 2 years.Your add reads let our experts solve your problem for free. So I click on Chat live now and up comes a page to charge for it so forget it, we will go to a different brand.
Dec 30, 2008 | KitchenAid Coffee Makers & Espresso...
Getting err4 on my cofee pot help
ERR 4 in a Kitchenaid coffee maker indicates a button is stuck in place. Please be sure to check all of your buttons and see if any are compressed into the machine.
Dec 30, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
I have Err 4 on my coffee maker... help
If “Err4” appears on the brew
timer display:
on the display, repeat this procedure.
• If “Err1”, “Err2”, or “Err3”
appear on the brew timer
display:
Press the On/Off Button to reset the
Coffee Maker. If the error codes
reappear, there is a problem with the
Coffee Maker electronics. Please refer
to the Warranty and Service section
beginning on the following page.
If the problem cannot be fixed with
the steps above, please refer to the
Nov 25, 2008 | KitchenAid KCM511 Coffee Maker
I have a Kitchenaid coffee pot model KCM515 and have lost the manual. It is not working & display is err4. What does this mean? jgit
A .pdf user manual and exploded parts views for this machine are available online at Kitchenaid.com. Click "Customer Care" in the upper-right hand corner of the main page and then click "Locate Manuals and Guides." You will need to enter your model number exactly as it appears on the bottom of the appliance. You should find it on a white sticker.
If this is not helpful, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Oct 16, 2008 | KitchenAid KCM514 Coffee Maker
I have an err4 on my kitchenaid coffee pot. I have unplugged it several times and pushed each button each time but it keeps popping up with the error. It turns on every time I plug it back in before the...
Had the same problem after cleaning. ERR4 is the result of moisture in the electronics. FIRST UNPLUG COFFEE MAKER. Get a long philips screwdriver and remove the 4 screws at the bottom of the coffee maker. Pull the bottom off and carefully unclip the front panel. The circuit card is simply clipped in so it removes nicely by unclipping with your fingers. Now take a hair dryer and dry out the circuit card. Carefully plug the maker back in and verify that the LED nolonger reads ERR4. Reassemble and your back in business!
Sep 07, 2008 | KitchenAid KCM511 Coffee Maker
Coffee pot
ERR 4 simply indicates that the computer is recognizing a stuck button (a button have been depressed for more than 10 seconds time). Please double check to make sure that no buttons are still depressed into the machine.
May 27, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
KitchenAid KCM511OB 10-Cup Coffee Maker Logo
1,799 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
