Question about Admiral AAV7000A
Admiral washer fills and continues to overflow
Off causes water to cut off so the water solenoind valve appears to work. Is there a fill switch or float valve to tell the silly thing that it's full? Easy to find and bang on?
    Novelist:
    Champion:
  • 261 Answers
Under the console attached to a rubber tube is your pressure switch which has failed. Use switch 21001882.
Posted on Oct 04, 2008
Washer overflows
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
Feb 13, 2014 | Frigidaire FGZ831A Top Load Stacked Washer...
Washer overflows as it agitate
The problem is going to be that the water inlet valve is sticking open and thusly needs to be replaced. It could have been a bad water level switch but since its does agitate that tells me that the water level switch is good or it would not agitate and fill at the same time yet if it were the problem it would fill and never start agitating. So that makes it for sure just the water inlet valve thats the problem.
GENE
Oct 09, 2011 | Admiral AW22 Top Load Washer
Washer is overflowing
The water input on washers is controlled by the timer which actuates the solenoid valves for both hot and cold water, telling them when to fill and when to close. I would run the machine thru a fill cycle with the washer back off, and with a voltmeter, observe if the voltage ever cuts off as the timer runs. I Another variable is the water level control. So also determine if that is working since if it failed to open the 'fill' circuit at the proper volume, you might have this overflow problem.
Aug 15, 2011 | Maytag Washing Machines
Washer keeps filling with water never shuts off overflows
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking.
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement.
Good luck, i hope this helps
Gene
Aug 04, 2011 | Kenmore 26422 Top Load Washer
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
Why do the stackable washers always overflow with water. Is it a sensor problem or what?
Overflowing can be caused by a faulty pressure switch or tube from switch to the tub. It is operated by air pressure from water filling in the tub. If this does not activate then the inlet valve will continue to allow water to enter the machine. If it is overflowing during spin only it is most likely something obstructing the pump. If it is filling the tub even when the machine is off the problem is the inlet valve.
Jun 28, 2010 | Maytag LSE7806A Top Load Stacked...
Water dose not stop runing and go into wash mode
Does your washer constantly attempt to fill and never does? Or, does the washer continue to fill and overflow?
If the washer is constantly trying to fill, but your water level does not change, you may have a condition known as siphoning. Siphoning occurs when you don't have a proper air gap on the drain line and the washer will actually drain as it attempts to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
If your washer fills, won't shut off and then overflows, this is caused by either a pressure switch malfuction, or a water inlet valve that won't shut off. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
I know the link is for a problem where the washer continues to fill even when it is not in use, but this problem occurs while the washer is running as well. The method of determing the cause is the same. In many cases, an overflow problem is caused by the air hose slipping off the pressure switch. Without the air hose, the pressure switch never detects the pressure differntial from the wash tub as it fills and won't shut off.
Read through the links provided and let me know if you have any questions. If the conditions I have described do not match your symptoms, please post back and elaborate a bit more so I can help you determine the source of the problem. Please include your complete MODEL NUMBER. I hope you find this information helpful.
Mar 28, 2010 | Kenmore 24032\24036 Top Load Washer
Our washer overflowed last night. no warranty on
Overflow is usually caused by a “stuck-open” fill valve, and the cold water half of the valve is usually the culprit. This can also be caused by the fill system control components: pressure switch, pressure tube, or pressure tube dome/port.First of all, determine whether your overflow condition is mechanical or electrical. Start the washer filling, then turn the timer off by pushing the knob in. If the fill continues, pull the washer plug. If filling continues with the washer unplugged, you have a mechanical problem - nearly always a stuck valve ***’y. Replace the fill valve.i f however, the fill stops when you unplug the machine, you are looking at an electrical fill control problem, Here a small piece of rubber or plastic tubing is handy. Unplug the washer and open the console where you’ll see the pressure switch. This is the switch with a small rubber tube, usually clear, sometimes black, attached. Pull this tube off and replace it with your short tubing. Blow a bit of pressure into the switch using your mouth, and listen for a click, then another when you release the pressure. Hear two clicks? Good! The switch is probably OK, Plug the washer back in (being aware that components in the console are now ‘hot’ and start the washer filling again. With it filling, again blow a bit of pressure into the switch. If the switch is good, the fill should stop and the machine should start to agitate.
This verifies that the pressure switch is working, and causes us to suspect the pressure tubing or a clogged port/dome to which it connects. Wipe off the end of the original tube you removed from the switch, and blow into it. You’re blowing air down into the tank now, and you should feel very little restriction. If it is very hard or impossible to blow through this tube, the tank dome or port is clogged..
Whatever your brand, if air can’t be blown back through this tube, the port or dome will need cleaning.
If you have no trouble blowing pressure through it remove the tube completely and inspect it carefully. This tube must not have the smallest hole in it, and we sometimes see them worn through or, more often, chewed through by mice. while it is the least common cause of overflow, it does happen and is easily overlooked. sometimes this tube will swell and loosen a bit, leaking air where it attaches to the tank fitting. If you suspect this, or the tube fits very loosely, simply cut 3/4” or so off the end and push it back on.
Sep 30, 2009 | Kenmore Washing Machines
What would cause the washer to overfill the tub?
If water is overflowing and you disconnect power to the machine. then:
A. It continues to fill: Replace water fill valve. (the part the fill hoses screw onto)
B. It stops filling: Most likely has a plugged tube from the tub to the water level switch.
Jul 27, 2009 | Washing Machines
I have a Admiral washer that fills with water but won't agitate
turn on your washer start programme while it is filling turn of power point if water still enters mchine you have a faulty water valve.if water stops there is a problem with the water level switch or hose that connects from outer bowl to pressure switch maybe perished or split.hope this helps you.
Mar 25, 2009 | Washing Machines
Admiral AAV7000A Logo
260 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
