Question about Cameras
How long does a full charge last in didigal camera
  • bclancey Jul 20, 2008
    forgot to say the camera is a kodak easy share zoom digital camera
Depends on what camera you are using, and what settings are being used.
Posted on Jul 20, 2008
Very low battery life
I have the same camera. It sounds to me that there is a fault with the camera itself and not the battery. You might be better sending Canon an email and asking them. My battery lasts forever so I would think if you already purchased another battery you've eliminated that problem. It might be the contacts inside the camera that are not accepting the full charge. Does the camera battery on screen show that it's full after you've charged it? Maybe trying charging it overnight and then trying it out the next day.
Dec 27, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
Batteries do not last anytime, after taking a few pictures get message "low battery".
The camera is running in reserve battery power. perform a full power charge usually expected to last an extire ccouple hours to makes camera useable once more. Prior to power charging battery on camera, power off the camera completely and allow to achieve full currrent replenishment.
Feb 03, 2011 | Mustek MDC 832Z Digital Camera
I have a new battery.For how long should I charge it?
Overnight for the first charge, then let it run empty.
The biggest mistake most people make is to use the camera for an hour or so, and then plug it back into the charger...Batteries have a memory of sorts, and eventually this habit causes the batt to only last for an hour or 2.
Rechargeables need to be stretched out and used to their full potential, inorder to realize their full potential.
After the first full charge-full discharge cycle, let it charge for 4-8 hours (depending on the type, charger, and manufacturer's specs, of course) and then allow it to sit for a few hours after use (to cool down) before putting it on the charger.
Apr 13, 2010 | Casio Exilim EX-Z77 Digital Camera
I plug my camera in to charge and for some reason the charging light goes out after approx. 30 seconds. Not sure why this is happening, but the battery won't charge
This would happen if the battery is busted ("memory effect", even if the newer batteries are touted to be immune - I found out this to be untrue).
The battery is behaving like a water reservoir - you pour in charge, you take out charge. Your battery is now full of silt, so that as soon as very little charge is added, the voltage immediately goes up, making the charging circuit believe the battery is full. But there's only drops in it.
A new KLIC-7001 battery (or compatible) should go for around ten bucks, and you can find compatible batteries up to 900 mAh - which should last appreciably longer than the original - for maybe twice that.
Feb 24, 2010 | Kodak Easyshare M753 Digital Camera
Canon 1000d display blank when power on,battery charge full
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Easyshare 721 battery problems
You need high-power re-chargeables - 2300 mAH or 2500 mAh
May 13, 2017 | Kodak EasyShare CX7430 Digital Camera
Casio ex-s880 model
It could be the battery isn't taking a charge. Since your purchased the camera last February you could be still covered under warranty. I would check with Casio.com. I found this link on their website:
http://www.casio.com/support/authorizedservice/
Jun 22, 2008 | Casio Exilim EX-S880 Digital Camera
Shoter battery life
well after a year of using the camera its battery slowly decreses and soon after a couple more years it wont hold its charge. you need to keep a back up battery
Nov 13, 2007 | Canon PowerShot S2 IS Digital Camera
Camera Not Coming on - Hung up
Usually the problem with this camera is the shutter won't open. I suppose it's good to be different :-) It sounds like it could be your batteries. If they are Alkaline chuck them and get NIMH the higher the mah the better. I use 2500mah and they last for a fair while. If you're using Nicads maybe they've developed a memory and they're not giving you full power. Lastly, if you are using NIMH maybe they're getting a bit old and can't deliver constant full power. Digital cameras can be very fussy with power requirements and anything short of the best can cause the problems you have and others. Go buy a new set of NIMH batteries, charge them for a full 14 hours and try them in your camera. I'll bet everything works like a charm. One other thing. If you are sure your batteries are fully charged remove them from the camera when the power dies and see if they are hot to the touch. If they are it means there is a short somewhere in the system. BMW
Jul 01, 2006 | Canon PowerShot A520 Digital Camera
S75 Battery Shelf Life?
It should easily last a few days. I didn't think the infolithium batteries lost its charge, but I could be wrong.
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
