Question about Electrolux Centralux Vacuum
I plugged in the hose this morning and the motor was running but not the vacuum. I went to the garage and the unit was unplugged. I plugged the unit back in but it still is not working. I noticed a black button the the side of the unit near the pilot light so I pushed that but still nothing. I also emptied the cannister and still it did not work.
Any ideas before I call the service guy in?
Thanks
L
    Scholar:
  • 44 Answers
If the light came on when you plugged it in, then you have power to the unit. You can take a coin and short across the two pins where the small, low voltage wires connect to the unit. Just remove the two wires, they should just pull off, and touch the two pins together with the coin. The unit should come on. If it doesn't, and the light is on, you may have a bad motor or a bad relay on the board inside the unit. Another thing to check is the filter. It has to be installed properly or the unit will not run. The top of the filter depresses a switch so that the unit cannot be operated without a filter in place. Good Luck!
Posted on Dec 31, 2008
My main power breaker for the house, shuts off after I have used the Electrolux Centralux vac for a short period of time - why does this happen?
This is usually an indication that the motor is going bad. Motors in central vacuum systems are very easy to replace. Most motors can be purchased online.
Aug 12, 2011 | Electrolux Centralux Vacuum
Lack of suction at power unit
Check that the Handle has a slider to adjust air flow, Electrolux Vac's arent really designed for carpet cleaning, check hose for breaks or cuts and everything is secure, while its on run your hands all over the hose and vac to locate any air flow that should not be.
Let me know.
Nov 15, 2007 | Electrolux Centralux Vacuum
When we plug in the hose the motor in garage runs but no air or suction comes out of the outlets. we cleared all the lines too.
Check to see if you have suction at the unit. If you have suction at the unit, your pipes are stopped up. If you don't have suction, you have a pipe loose under the house. Also you could just have a stopped up hose
Apr 29, 2010 | Electrolux Centralux Vacuum
My electrolux central vac clicks when I try to start but won't tu
It sounds like you have a bad motor. Motors can be replaced easily. You will need to know the model number. There are several companies online that sell replacement motors.
Aug 27, 2009 | Electrolux Centralux Vacuum
How to Reverse the hose at inlet on power unit on centralux E130A
That is the easiest way, just hold the attachment end of the hose into dirt inlet (preferably the one on the unit itself) and use your hands to try and seal the end as best you can.
Jun 25, 2009 | Electrolux Centralux Vacuum
Non-working Electrolux Centralux vacuum system
Is there a small LED light illuminated where the low voltage wires connect to the main unit? There may be a small rubber boot covering the connection and the light. Just slide it back, and there should be a green LED light if the unit has power. If the LED is not on, there is no power to the unit (tripped breaker, plug came loose from electrical outlet, etc.) If LED is illuminated, short across the pins where the low voltage wires connect to the main unit. (These will be small 18-22 gauge wires, not the larger electrical cable!) You can do this with a coin. (Don't worry, it's just 24 volts and you won't even feel it) The unit should come on. If it doesn't, and you have light from the LED, then it's probably the relay on the board inside the unit, or the motor. Good Luck!
Nov 14, 2008 | Electrolux Centralux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113669&thid=657359
Posted by Brucebob on Jun 09, 2008
I have an Electrolux Centralux. When I plug the hose in at one of the wall outlets the motor will not start. If I go to the motor and slap the unit it will start.....then...it will not stop unless I unplug the power cord to the motor.
If I plug the power cord back in, the unit will not restart until I slap the motor unit again. The unit has only been used 20 - 30 times.
Any suggestions? Thanks, Bruce
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You may have a bad inlet or household outlet; try all the inlets in the house too. But it sounds to me that your carbon brushes are dirty and need cleaning or replacing would be my 1st suggestion. Take a good wire brushes or pipe cleaner to clean the inside of the carbon brushes if they stick then replace them. So if the unit has only been used 20 to 30 times I would suggest some one to come and look @ it who did the install because it is still under a factory warranty and if you start messing with things you will void the factory warranty on the motor. And then if it is the motor for some reason then the factory or vendor will eat the cost of the repair. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Electrolux Centralux Vacuum
Electrolux Centralux Vacuum Logo
106 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
