How do I adjust the color?....Too much "green"
I will check out the warranty, thank you.
Posted on Jul 22, 2008
Perblem lg37lb1r has a color very often the color of green blindon
You can adjust the green temperature at the color RGB adjustment.press the menu button then choose the video adjust then scroll down to RGB setting RGB stands for RED,GREEN AND BLUE..adjust it according to your preference..
Apr 06, 2012 | LG 37LB1R 37 in. HD-Ready LCD Television
Tip
SERVICE MODE AND POWER SUPPLY ADJUSTMENT
FUNAI LED40-H9200M
White Balance Adjustment
Purpose: To mix red and blue beams correctly for pure white.
Symptom of Misadjustment: White becomes bluish or reddish.
1. Operate the unit for more than 60 minutes.
2. Set the color analyzer at the CHROMA mode and zero point calibration. Bring the optical receptor pointing at the center of the LCD-Panel.
3. Enter the Service mode.
4. Press [ VOLUME -- ] button three times on the remote control unit to select "Drive setting" mode. "Drive" appears on the screen.
5. Press [3] button to select the "HDB" for High Drive Blue adjustment. ("HDB" appears on the screen.)
6. Press [MENU] button. The internal Raster signal appears on the screen. ("Internal (Single)" appears on the upper right of the screen as shown below.)
7. Press [P UP /DOWN ] buttons to adjust the color temperature becomes 12000°K (x= 0.272 / y= 0.278 ±0.002).
8. Press [1] button to select the "HDR" for High Drive Red adjustment ("HDR" appears on the screen.) and press [P UP/DOWN ] buttons to adjust the color temperature.
9. If necessary, adjust the "HDB" or "HDR" again.
10. Press [6] button to select the "LDB" for Low Drive Blue adjustment ("LDB" appears on the screen.) and press [P UP/DOWN ] buttons to adjust the color temperature.
If you wish to get some details; check the site linked here. Pull up older posts
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
on Feb 21, 2015 | Funai Philips 40" LED Wifi IPTV - Black...
I replaced the Convergence chip on my WS55511, and now the colors align properly, so there isn't a convergence problem. But the picture still isn't right. The colors shift towards red in the...
You have your input R G B / component wires hooked up incorrectly. The tv is detecting that and letting you know. disconnect and redo observe the color matching.
Oct 06, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Have a 27 " JVC
Hi ,
welcome to Fixya, it sounds like you may have a weak CRT (picture tube)
If the TV is over 6 years old that may be the case.
There are RED, Blue and Green color balance adjustments that you can try .
referencing the exact model one could see how it adjusts.
hope this helps
Roety
Mar 11, 2011 | Televison & Video
Wont autofocus, bow in blue color at top, cant adjust blue convergence
hello it's the convergance chips my be the problem get a quote from an engineer its a big job 2 do yourself trust me i've repaired a few my self i hope you get it fixed good luck
shaun
May 21, 2009 | Samsung Televison & Video
My monitor has a green hue that will not go away when I adjust the colors in the screen. The blue adjuster doesn't seem to do anything. When I use auto adjust, It looks amazing for about 5 seconds then...
If you have another PC try it on the monitor, see if the problem persist. I f it doesn't check your video card's control panel. Some configuration there, may be overriding your monitor's. If you have an nvidia based card run the "optimize my display wizard"
May 08, 2009 | AOpen F2715-8S Monitor
Picture is in reds and greens
Try doing a "factory reset". This will "burp the baby". Turn the set on and ignore what you see. From the side control panel, push the volume+ and channel+ buttons in synch. This will take you to a base OSD (on-screen display) that can best be compared to the BIOS on your PC. The real goodies are here.
On the OSD, you'll see "picture", "audio", and "advance". Using standard navigational input on the remote, go to "advance". Tab down to "clear all". The set will appear to turn off, but the front LED will remain blue. The set is re-formatting the on-board memory and will restart in a few seconds.
Your panel should now restart as normal, but will be returned to factory "burn-in defaults". Your color and audio adjustments will be lost, so you'll have to do some fine-tuning in the regular OSD menu. Cycle power to the TV after you have made the desired adjustments.
TIP: Perform the factory re-set a second time, then select "picture". Toggle down to "video format". You might find it set to "Pal". Change this, using standard navigational input on the remote, to "NTCS" or "AUTO". Cycle power to the TV after you have made the desired adjustments. The TV will now perform at a refresh rate of 60hz, the American standard. "Pal" is 50hz, the EU and Asian standard. The improvement to image quality will be noticable very soon, as both your eyes and the set adapt to 9.94 hz improvement. NOTE: You may need to fine-tune the TV again after making this change.
Mar 21, 2009 | Polaroid FLM-3732 Television
Green screen
Mar 14, 2009 | Polaroid FLM-3732 Television
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
