Question about Sony Televison & Video
When first attempting to turn on my 60" XBR Blinks green on power indicator, Tv turns on a split second and light turns to red and blinks 4 times. Please help me understand what is happening.
Thanks for your support with my situation. I read many people's complaining about having a red light blinking 4 times in the Pwr. display. It was recommended I blow out the fan for the bulb. I did just that and it did solve the problem, at least for now.
The fan kicked on which allowed the Tv to power up.
I am guessing this is a common issue and made sense that the fan was stuck with dust.
I can't thank your site enough for this valuable information. Spending 4k and already having one unit replaced with what was a factory inherent problem and then going down so quickly was very upsetting.
I am hopeful it will work for now on.
Randy Winters
Posted on Jul 21, 2008
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
TV blew out
if the lamp light is flashing u need to replace the lamp. u should have instructions on the set or in the manual
Dec 07, 2008 | Televison & Video
Problem turning on the TV
I have the same problem. Did you find a solution?
Oct 24, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Televison & Video Logo
59 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
